This integral solveable [itex]\int^{3.5}_{0.5}(sin(x*π)+1)^adx[/itex]?
  • Thread starter Thread starter no_alone
    Integral
no_alone
Hello I am trying to find a normalizing factor for
\int^{3.5}_{0.5}(sin(x*π)+1)^1dx
I want that the integral of \int^{3.5}_{0.5}(sin(x*π)+1)^a dx *factor = \int^{3.5}_{0.5}(sin(x*π)+1)^1dx
So for this I need to solve the integral
But I did not mange to solve it.
I did found that when I do = a = [1,2,3,4,5,6,7]
I find in wolfram this:
http://www.wolframalpha.com/input/?i=2+3+5+8.75+15.75+28.875
in the end of the page we can see a possible sequenct identification:
α_{n} = \frac{2^{n}* (\frac{3}{2} )_{n-1} }{(2)_{n-1}}
when σ_n is the Pochhammer symbol.
Thank You.
Here is what Mathematica gives:
\int_{\frac{1}{2}}^{\frac{7}{2}} (\sin (\pi x)+1)^a \, dx =
\frac{2^a \left(3 \sqrt{\pi } \Gamma \left(a+\frac{1}{2}\right)-2 \Gamma (a+1) B_0\left(a+\frac{1}{2},\frac{1}{2}\right)\right)}{\pi \Gamma (a+1)}
provided ##\Re(a) > -1/2##. ##\Gamma## is the gamma function and ##B_0## is the incomplete beta function.
If appears that you are only worried about a being a positive integer. If that's the case, denote ##k_a \equiv \int_{1/2}^{7/2} (1+\sin(\pi x))^a\,dx##. Expand this as ##k_a = \int_{1/2}^{7/2} (1+\sin(\pi x))^{a-1}\,dx + \int_{1/2}^{7/2} (1+\sin(\pi x))^{a-1}\sin(\pi x)\,dx = k_{a-1} + I_a## where ##I_a \equiv \int_{1/2}^{7/2} (1+\sin(\pi x))^{a-1}\sin(\pi x)\,dx##. Integrate this by parts. You should get a linear combination of ##k_{a-1}## and ##k_a##. Solve ##k_a = k_{a-1}+I_a## for ##k_a##. This will give a recursive relation for ##k_a## in terms of ##k_{a-1}##. You know ##k_1##, so this will let you solve for ##k_a## in terms of ##a##.
Likes no_alone
Thank You.
Do you, but this will not help me, Because in your solution, I need to calculate the gamma function, and this is also an integral. I can do it computationally .. But I can just calculate the first integral.
Thank You D H.. But I also a=0.1 0.5 1.5 ... I am also worried about a being not integral ( but I do not care if it is not positive ).
Your solution will help me for integer a. :-)
JJacquelin said:
So, do you mean that you cannot calculate the exp function, nor the log function ? They are also integals, just as the gamma function and many other special functions :
http://fr.scribd.com/doc/14623310/S...tions-Safari-au-pays-des-fonctions-speciales-
Thank You, I write a program that should normalize the integral for every α. and I write it in a wrapper for c.. all I have are those functions:
http://www.neuron.yale.edu/neuron/static/docs/nmodl/nmodlfunc.html
I do not have the gamma function and incomplete beta function.
