Calculating the Force on Electron Near a Long Straight Wire
  • Thread starter GreenDinos
In summary, the conversation is about finding the magnitude and direction of the force acting on an electron due to the magnetic field of a long straight wire carrying a current of 20 A. The electron's velocity is directed towards the wire and it is 3 cm away from it. The conversation includes discussions about the equations and methods used to find the force, as well as confusion and mistakes made by the participants. Ultimately, it is determined that the force is parallel to the current and the correct magnitude is found to be -4.272X10^-16.
GreenDinos
Grr I've been trying to figure this out and I'm just getting frustrated because I can't find any help in my book...
A long straight wire carries a current of 20 A. An electron, traveling at 2X10^7 m/s, is 3 cm from the wire. What force (magnitude and direction) acts on the electron if the electron's velocity is directed toward the wire?
given: ok, so i know that the wire is long and straight (so i know how its magnetic field will act) and i know the current in it..I also know the charge on the electron..it's velocity and its distance from the wire...
I'm supposed to find the magnitude and direction of the force acting on the electron... Ok- so let's say the wire is coming out of the page- i know the magnetic field will be counter-clockwise so in that case, the force would be "up" (perpendicular to the current.) I can find the force on the electron due to the magnetic field at it's current point using the equation B= (uoI/2pi r)
where uo is the constant. I really don't know though how to adjust this for the charge on the electron or the velocity. I know how a charge would act in a uniform magnetic field and i remember that when a charged particle moves it creates an electric field- so i know if a electron moves from infinity to any location close to a proton or electron i can find the force...
gah i can't figure it out! please help!
You need to know how to find the magnetic force on a moving charge:
[tex]\vec{F} = q \vec{v}\times\vec{B}[/tex]
yeah i tried that- here's what i have done:
i got the value of B to be 1.33X10^-4 I then used F=qvBsin(90) and got the force to be -4.272X10^-16 which it says is wrong
I also put in that the force was going to be perpendicular to the current but apparently that was wrong because I missed it (and i only get one shot)- grrrr!
it turns out the force is parallel or the current?? i don't understand that- i look at it again and figured it to be antiparallel (using the right hand rule)
.oh wait- duh...MAGNITIDE no it's not a negative number...nevermind...
still does anyone understand why the force would be parallel and not antiparallel to the current in the wire?
[edit: This is correct.]
[edit: This is the correct magnitude.]
It's certainly not perpendicular to the current! How did you get anti-parallel? If the current is out of the page, the B field is counterclockwise, and -v x B is out of the page and thus parallel to the current.
Edit: I had originally said that GreenDinos's numbers were wrong--my mistake: I dropped an exponent in doing the arithmetic. :uhh:
off by a trillion? it was the right answer- it just wanted magnitude which means the absolute value.- i realized this then it said it was correct
perpendicular- i got this at first because i was thinking about a point in space- if the current in the rod was coming out of the page towards you the magnetic field is counter-clockwise- if there was a point there (let's say north of the wire) it would feel the force perpendicular to the wire- to the west.
Ok then i realized it's different for a moving particle- I drew a figure where the current ran in a wire from south to north (from left to right on the page) which means that above the wire, the magnetic field it out of the page and under it it is into the page. Here, no matter if i put the electron above or below the wire i get antiparallel- i use the right hand rule where my fingers are in the direction of v then i curl them towards B- where my thumb points is the force. every time it points to the opposite of where the current is running.
...oh wait- because it's negative that you do the opposite of the right hand rule...ok
Oops... my mistake. I dropped an exponent. Your answers are numerically correct. Sorry about that!
That's it!
What is the equation for calculating the force on an electron near a long straight wire?
The equation for calculating the force on an electron near a long straight wire is F = (μ0*I)/2πr, where μ0 is the permeability of free space, I is the current in the wire, and r is the distance between the wire and the electron.
What is the direction of the force on an electron near a long straight wire?
The force on an electron near a long straight wire is always perpendicular to both the wire and the direction of the electron's motion. This means the force will either push the electron towards or away from the wire, depending on the direction of the current in the wire.
How does the force on an electron near a long straight wire change with distance?
The force on an electron near a long straight wire follows an inverse relationship with distance. This means that as the distance between the wire and the electron increases, the force decreases. Conversely, as the distance decreases, the force increases.
What factors affect the force on an electron near a long straight wire?
The force on an electron near a long straight wire is affected by the strength of the current in the wire, the distance between the wire and the electron, and the permeability of free space. Additionally, the presence of other nearby objects or magnetic fields can also influence the force.
Is the force on an electron near a long straight wire always attractive?
No, the force on an electron near a long straight wire can be either attractive or repulsive depending on the direction of the current in the wire and the direction of the electron's motion. If the current and electron motion are in the same direction, the force will be repulsive. If they are in opposite directions, the force will be attractive.
