Thought experiment / paradox question
NateTG
Let's say I start out with a (spin) neutral electron beam. Now, I can place an up/down Stein-Gerlach spin filter/detector in the beam so that I have a running tally of the "up" electrons, and a spin-down exit beam.
Since the measuring device is accumulating spin-up electrons, it should also be accumulating net spin-up.
Now, let's say I have a terminal for the beam, which splits the beam into left and right spin electrons using a Stein-Gerlach device, and takes counts of both. Now, the terminal is interacting with (what I expect to be) a roughly equal number of spin-up and spin-down electrons, so there should be no net accumulation of spin in the terminal.
This seems problematic because the filter is accumulating net spin without conservation of spin. What am I missing?
NateTG said:
What am I missing?
The angular momentum in the magnetic field of the second apparatus.
For each individual |z+> -> |x+> transition, there is a transfer of Lz from the electron to the magnetic field ; and for each |z+> -> |x-> transition, there is an EQUAL transfer of Lz from the electron to the magnetic field.
Of course, for the |z+> -> |x+> transition, there was a positive contribution of Lx from the field to the electron, and for the |z+> -> |x-> transition, there was a negative contribution of Lx, so the Lx contribution averages out to 0, but not the Lz contribution.
There's a net flow of Lz momentum from the electron beam to the B-field (and hence to the magnet).
cheers,
Patrick.
Sure, that makes sense, but doesn't that lead to a problem because you could know the spin state in two dimensions for a bunch of electrons?
Let's say we have an EPR-like set up with an entangled electron source, and an up-down split count target on one side, and a left-right split target on the other. And, using timing we manage to restrict our runs to getting 5 electrons at a time. Then there's a 1 in 1024 chane that all the hits on the up/down detector will be up, and all the hits on the left-right detector will be right. Thus we would 'know' that all of the electrons that hit the up/down detector would have to have been up/left electrons, but those measurements don't commute, and thus be able to measure (and predict) the net spin of the targets?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
