Tidal force, torque and precession
23 replies · 8K views · last reply
tim_lou
imagine a sun and a planet, both rigid and perfectly spherical. the distance between the center of mass of these two bodies is much greater than the radius of both bodies.
considering Newton's inverse square law of gravity:
now, due to the non-uniform nature of this gravity, different parts of the planet experiences different forces. let's say the planet is spinning around a axis with a non-zero inclination angle. the tidal forces would actually result in a torque even though the planet is perfectly spherical and it would result in precession. i have worked out some basic intrgrations and approximation regarding this problem. perhaps someone can tell me if it has been discovered before and information about it? i know tidal force... but what about "tidal torque"?
is there any actual calculation/derivation on these things? i couldn't find any online.
I'm not sure you'll have any tidal effects if both objects are "rigid and perfectly spherical."
There would be no torque if the planet were "perfectly spherical".
The Earth's precession is due to its slightly uneven shape.
Yes. If the center of mass is not the physical centre of the sphere the sphere will experience a tidal torque from a single gravitational source. In the Earth's case, however, I think the reason for precession has more to do with the gravitational forces being supplied by two sources, the moon and earth.
AM
that is i think why the idea is catchy. there is torque if the planet is spinning on a tiled axis.
the center of mass does not always coincide with the "center of gravity" in a non-uniform gravitational field. hence there will be a torque...
i do not know to what extent this torque affects the precession. i do know that it is quite significant.
it is approximately proportional to radius^2/distance^3 and sin(angel of inclination*2)
(if my math works out are correct... i did some simple integrations)
i don't konw how much the moon contributes to the torque... maybe someone knows? i couldn't find it on google.com or anything...
I agree. As far as the request for sources go, I would suggest that the OP look it up in "Classical Mechanics" by Goldstein. In the second edition, Goldstein ssay:
pg 225
Were the Earth competely spherical, none of the other planets could exert a torque on it.
A useful formula here is MacCullagah's formula is derived on pg 228, one can find various online sources as well that also cover some of this material, for instance
http://scienceworld.wolfram.com/physics/MacCullaghsFormula.html
http://geophysics.ou.edu/solid_earth/notes/maccullagh/maccullagh.html
This formula gives the potential function for a point mass orbiting a non-spherical planet. What is important are the moments of inertia of the planet around it's three principle axis (A,B, and C on the scienceworld webpage).
It's common to assume A=B (see the bottom page of the scienceworld url), then one can see that the potential function for a point mass consists of the usual potential plus a multi-pole potential proportional to (C-A).
In some cases (for instance the tidal torque on the moon), one has to deal with the fact that the Earth isn't a perfect figure of revolution (i.e. A is not equal to B), but usually it's not necessary, one usually only has to worry about the fact that C is not equal to A.
Sometimes the factor J2 is used instead to represent the oblateness parameter (see the bottom of the second webpage above).
thx man, never know that these ideas and formulae existed until you pointed it out. too many names, too little explicit explanations on formulae until you learn them... hmm got to take more time to digest it.
i have to disagree on this one... i can't explain very well...so i'll post a diagram.
the "center of gravity" does not coincide with the center of mass... (i know "center of gravity" is not a very good word in non-uniform gravitational field...but i don't know how else i can explain it).
if you rotate the planet such that the z-axis is the axis of rotation(the planet is spinning around it),
theata is the angle of inclination.
the net torque would be...
I'm pretty sure that the integral isn't zero. there is no symmetry, and i did some approximation which does not really equal zero.
correct me if I'm wrong.
i used a lot of approximations and the integral turned out to be approximately,
[itex]\tau=\frac{3GMmr^2sin{2\theta}}{5d^3}[/itex]
i will explain my results if anyone thinks that my logic is correct... i gave this project to my physics teacher and he didnt have much to say...
if my idea is correct, then i'll continue to work on and see what the precession period will be solely based on this idea (for a planet in a spherical orbit). if this is significantly smaller than other theories predicted... we might have something here. (i'll need a lot of help from you guys though)
The Earth is basically very close to an equipotential surface (with minor variations, such as mountain ranges and valleys).
Because it is rotating, it has a distinct equatorial bulge
Without this equatorial bulge, there will be no torques on the Earth. The rotation doesn't matter to the force in Newtonian gravity. The force between two perfect spheres acts as if the force were at the center of mass - it doesn't matter whether or not they are rotating. It is only imperfections in the spheres (due to equatorial bulges or tidal bulges) that can cause torque.
I'd have to see more of your derivation to find your mistake - but as I said, Goldstein works thorugh a lot of this stuff, and he introduces the chapter in which he does so with the remark that I quoted, about how no planet could produce a torque on the Earth if it were perfectly spherical.
actually the idea came from how spinning ball on a table curve... so i thought why not gravity?
also, from wikipedia:
http://en.wikipedia.org/wiki/Center_of_gravity
"The center of mass is often called the center of gravity because for at least two purposes, any uniform (constant) gravitational field g acts on a system as if the mass were concentrated at the CM"
however, Newton's law of gravity is not uniform.
"If the gravitational field acting on a body is not uniform, then the center of mass does not necessarily exhibit these convenient properties concerning gravity."
quote from wikipedia from feyman's lecture on physics:
"The center of mass is sometimes called the center of gravity, for the reason that, in many cases, gravity may be considered uniform. ...In case the object is so large that the nonparallelism of the gravitational forces is significant, then the center where one must apply the balancing force is not simple to describe, and it departs slightly from the center of mass. That is why one must distinguish between the center of mass and the center of gravity."
that's why i thought perhaps if a planet is big enough, the approximation of gravity acting on the center of mass is not enough...
i honestly do not have Goldstein's book... so i do not know any of his argument.
My math is not all that good... and my derivation is somewhat lengthy (10 pages with diagrams), it also uses a different x,y,z axis for integration... i'll have to clean that up before posting it here...
my math is really messy... the whole thing has more than 10 pages...and i approximate the first integral over and over again so that it can be integrated again... anyway, i cut all the fat in the following article.
the following is a simple "proof" that i put up to prove that the torque is indeed non-zero. i don't know if it is correct, but i checked it many times... although i often make stupid little mathematical mistakes. i has the "proof" but non of the "fat".
I think that the torque should be (x,y,z) x force, that that is where the error is. (You have (x,y,0) x force).
Think about an x-component of force on the top of the sphere, for instance (0,0,zmax).
There will be a torque along the y-axis due to this force. You are not including this component of the torque in your analysis of the y-component of the torque.
On a related issue, there should be no difference in the torque produced on a sphere when it is rotating or when it is not rotating. The torque is still radius x force
So you can simplify the problem immensly more than you've done - the rotation doesn't matter to the torque, and there is spherical symmetry to the problem (not just axis symmetry).
the reason why it is <x,y,0> is because z is the axial of rotation. <x,y,0> is the moment arm, the component of the position vector that is orthogonal to the rotation axial. i have carefully thought about what should happen when it is non-spinning:
lets assume that the planet is not spinning, and my theory is correct. then, it will experience a torque in the y direction. Let's say now it will start to spin and gain angular momentum in the y direction. however, that mean the axial of rotation will the y axis, not the z axis, a contradiction. now, if the axis of rotation is the y-axis, no torque will be produced. the "moment arm" is paraelle to the "net gravitional" force. r cross F=0
however, the torque can exist when rotation exists. the angular momentum will simply go into precession. energy is conserved because the torque is always orthogonal to the L vector.
hmm, <0,0,zmax>, the moment arm is a zero vector<0,0,0>...it is a point at the axial of rotation...r cross F=0. yes, there will be a torque produced when another axial is chosen. but... how would it make sense to pick a rotation axial other than the one that the planet is spinning around? it would lead to contradiction at the end...
The spinning planet is like a gyroscope. When you apply a torque to it, it will tend to precess. But this does not change how the torque is computed. One still uses r X F to compute the torque.
It's easiest to see how a x-directed force on the non-spinning north pole of the Earth, spinning about the z axis, causes a torque on the y direction. But the calculation for torque is the same regardless of whether the Earth spins or is stationary. The velocity is not relevant to the caclutation of torque - it is still rXF, even if the point to which the force is being applied by gravity is moving.
What does happen is that
[tex]\vec{\omega} = \vec{\omega_0} + \vec{\tau} t[/tex]
where [itex]\omega[/itex] is the angular velocity of the Earth (expressed as a vector), and [itex]\tau[/itex] is the torque, expressed as a vector.
This means that if one applies a toruqe along the y-axis to an Earth spinning on its z axis that spin axis moves in the y-z plane, as one expects from a vector addition. You can feel this behavior if you apply torque (i.e. try to twist) a spinning gyroscope.
i see what you are saying, around the y-axis, there will be torque produced by a force in the x-direction at the north pole.
do you agree that there is a non-zero torque produced by the sun around the axis of rotation?
so, you are saying that this torque will somehow be canceled by torque produced in a different axis right? and the "net" torque should be the sum of all torques calculated in all 3 principle axis right?
btw, spot your typo there, hehe, you meant [tex]\vec{L}=\vec{L_0}+\vec{\tau}t[/tex] ?
after much more thinking... i think my mistake is really not taking into account of torques calculated in other principle axis since informations are lost when only one particular axis is chosen for calculation
I guess in 3D free space things are different than normal day situations... well, at least i learned it the hard way... 10 pages of "attempting" to derive something incorrect go to waste. Anyway, at least now i understand the idea of rotations and torque much much more clearly (and i had fun).
how do you actually calculate the net torque though? pick an axis then... ? what are the actual equations used to calculate the net torque in 3 dimensional spaces?
i still need to varify that the torque is indeed zero when it is all added up though...
Yeah, I need to revise the formula, good catch.
When the moment of inertia is the same around all three principle axes, we can write
[tex] \omega =\omega_0 + \alpha t[/tex]
where [itex]\alpha I[/itex] = torque
I being the moment of inertia (assumed to be the same on all 3 axes).
just as we can write v = v0 + a*t
But if the moment of inertia tensor isn't the same in all three directions, we need to deal with the angular momentum, as you suggest.
torque = dL / dt = d(I [itex]\omega[/itex]) / dt
Unfortunately both I and [itex]\omega[/itex] are functions of time, so one winds up with Euler's equations when all is said and done.
http://en.wikipedia.org/wiki/Euler's_equations
But calculating the net torque on a system isn't nearly as involved as this. You just need to sum up r X force around the point that you chose (usually, the center of mass). THat's all there is to it. Chose a point, and sum up the cross product of r x force.
There's an easy way to show that a spherical body doesn't generate any torque from interacting with a point mass, however.
By symmetry, the force on a point mass always points towards the center of the sphere - it's a central force.
This means that the angular momentum of the point mass around the center of the sphere is not changed. (r X force is zero, because r points in the direction of the force, as the force is a central force).
If the angular momentum of the point mass doesn't change due to the force exerted on it by the sphere, and angular momentum is conserved (which it is), the angular momentum of the sphere around it's center of mass can't change due to the force exerted on it by the point mass. If it did, angular momentum would not be conserved.
Another way of saying this - one specifies a point around which torques are going to be measured.
Then the torque exerted by a large, irregularly shaped body on the point mass is going to be equal and opposite to the torque exerted on the point mass by the large, irreguarly shaped body. (Both torques are measured around the same, specified point, whatever that point may be).
MacCullagh's formula, which I gave earlier, can be used to find the torque on a specified point mass from a non-spherical body. Because torques come in equal and opposite pairs just like forces, the same formula gives the the torque that the point mass exerts on the non-spherical body.
The formula gives the correct result that the torque is zero for a sphere.
thx, i see what i did wrong now. i guess i'll work on the real deal here. the real torque generated by the moon, the sun due to Earth's slightly abnormal shape.
i guess you don't really know something unless you make some mistakes... knowledge is knowing what you do not know... well, i guess i know what i didnt know.:wink:
problem resolved.
Is it just the equatorial bulge that causes gravitational torque or is it also the fact that the ocean water moves in response to the tidal forces? Both cause the Earth to deviate from a perfect spherical shape.
AM
Even solid planets will tend to "tide-lock" their moons. Howver, frictional forces are an important to the rate of tide-locking, because they affect the position of the bulges, and the position of the bulges affects the forces. (THe more "lag" in the bulges, the greater the force).
In fact without some energy loss mechanism, tide-locking would not occur at all - so some sort of frictional loss mechanism is very important.
