Tides and Moon Gravitational Force
The Moon's gravitational force creates tides in the oceans by exerting a differential pull, which is less effective on small objects like stones due to their weight and friction with the ground. The gravitational gradient affects larger bodies of water more significantly, allowing them to move freely compared to stationary stones. While the Moon does exert a pull on stones, the Earth's gravity and friction keep them in place. The ocean's fluid nature allows it to respond to the Moon's gravitational pull, unlike solid objects. This distinction explains why tides occur in water but not with loose stones on land.
gianeshwar
We know Moon creates tides on seas.Then why doesn't Moon pull loose stones or other objects lying loose on earth?
It pulls the stone, and the surface under the stone almost equally. The gradient in Moon's gravity is less than the attraction of the stone by the Earth.
Thanks AT.Why did you use the word gradient?
Gradient is approximately the difference in gravitational field between two points. The stones are small objects so the moons gravity has the same effect on the whole stone, unlike the ocean. The pull on the ocean "under" the moon is bigger than the pull on the ocean on the opposite side of the earth
Likes 1 person
The difference between small stones on land and small bits of water, in the sea, is that the stones are held back from moving by friction but the static friction in water is very low - so it can move. Try to make a pile of water and then a pile of stones - you will see what I'm getting at.
Likes 1 person
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
10K
