What Can You Create with TikZ Code Examples?
  • MHB
  • Thread starter MarkFL
In summary: Lines \draw[important line] (.15,.15) coordinate (A) -- (.85,.85) coordinate (B) node[right, text width=5em] {$y=x$}; \draw[important line] (.15,.85) coordinate (C) -- (.85,.15) coordinate (D
MarkFL
MHB
13,288
I thought it would be nice to begin a thread where we can post examples of TikZ code that the community can use as templates or jumping off points for their own images. I would recommend not posting a huge number of images in the same post, so we don't strain the rendering server (maintained by I like Serena), or MHB's server.
I'll begin with a Sudoku 3D cube:
\begin{tikzpicture}[every node/.style={minimum size=1cm},on grid]
%preamble \usetikzlibrary{positioning}
\begin{scope}[every node/.append style={yslant=-0.5},yslant=-0.5]
\shade[right color=gray!10, left color=black!50] (0,0) rectangle +(3,3);
\node at (0.5,2.5) {9};
\node at (1.5,2.5) {7};
\node at (2.5,2.5) {1};
\node at (0.5,1.5) {2};
\node at (1.5,1.5) {4};
\node at (2.5,1.5) {8};
\node at (0.5,0.5) {5};
\node at (1.5,0.5) {3};
\node at (2.5,0.5) {6};
\draw (0,0) grid (3,3);
\end{scope}
\begin{scope}[every node/.append style={yslant=0.5},yslant=0.5]
\shade[right color=gray!70,left color=gray!10] (3,-3) rectangle +(3,3);
\node at (3.5,-0.5) {3};
\node at (4.5,-0.5) {9};
\node at (5.5,-0.5) {7};
\node at (3.5,-1.5) {6};
\node at (4.5,-1.5) {1};
\node at (5.5,-1.5) {5};
\node at (3.5,-2.5) {8};
\node at (4.5,-2.5) {2};
\node at (5.5,-2.5) {4};
\draw (3,-3) grid (6,0);
\end{scope}
yslant=0.5,xslant=-1},yslant=0.5,xslant=-1
\shade[bottom color=gray!10, top color=black!80] (6,3) rectangle +(-3,-3);
\node at (3.5,2.5) {1};
\node at (3.5,1.5) {4};
\node at (3.5,0.5) {7};
\node at (4.5,2.5) {5};
\node at (4.5,1.5) {6};
\node at (4.5,0.5) {8};
\node at (5.5,2.5) {2};
\node at (5.5,1.5) {3};
\node at (5.5,0.5) {9};
\draw (3,0) grid (6,3);
\end{scope}
\end{tikzpicture}
And a belt and pulley system:
\begin{tikzpicture}
% Definitions
\pgfmathsetmacro{\b}{75}
\pgfmathsetmacro{\a}{15}
\pgfmathsetmacro{\R}{2}
\pgfmathsetmacro{\r}{1}
\pgfmathsetmacro{\P}{\R*tan(\b)}
\pgfmathsetmacro{\Q}{\R/cos(\b)}
\pgfmathsetmacro{\p}{\r/tan(\a)}
\pgfmathsetmacro{\q}{\r/sin(\a)}
% Pulleys
% Big pulley
\draw (0,0) circle (\R) ;
\fill[left color=gray!80, right color=gray!60, middle
color=white] (0,0) circle (\R) ;
\draw[thick, white] (0,0) circle (.8*\R);
\shade[ball color=white] (0,0) circle (.3) node[left,xshift=-5] {$P$};
% small pulley
\draw (\Q+\q-.3, 0) circle (\r);
color=white] (\Q+\q-.3, 0) circle (\r) ;
\draw[thick, white] (\Q+\q-.3,0) circle (.8*\r);
\shade[ball color=white] (\Q+\q-.3,0) circle (.15)
node[right, xshift=2] {$Q$};
% belt and point labels
\begin{scope}[ultra thick]
\draw (\b:\R) arc (\b:360-\b:\R) ;
\draw (\b:\R) -- ( \P, 0 );
\draw (-\b:\R) -- ( \P, 0 );
\draw (\Q-.3,0) -- + (\a:\p) arc (105:-105:\r) ;
\draw (\Q-.3,0) -- + (-\a:\p);
%\draw (\b:\R) arc (\b:360-\b:\r) ;
\end{scope}
\draw (0,0) -- (\b:\R) node[midway, above,sloped] {$R$} node[above] {$A$};
\draw (-\b:\R)--(0,0) ;
\draw (\Q+\q-.3,0) -- +(105:\r) node[midway,above, sloped] {$r$}
node[above] {$E$};
\draw (\Q+\q-.3,0) -- +(-105:\r) node[below] {$D$};
\node[below] at (-\b:\R) {$B$};
\node[below] at (\Q-.3,0) {$C$};
% center line
\draw[dash pattern=on5pt off3pt] (0,0) -- (\Q+\q-.3,0);
% angle label
\node[fill=white] at (0.73*\Q, 0) {$\theta$} ;
\draw (\Q-1.8,0) arc (180:195:1.5);
\draw (\Q-1.8,0) arc (180:165:1.5);
\end{tikzpicture}
Escher Brick:
\begin{tikzpicture}[scale=4.5, line join=bevel]
% \a and \b are two macros defining characteristic
% dimensions of the impossible brick.
\pgfmathsetmacro{\a}{0.18}
\pgfmathsetmacro{\b}{1.37}
\tikzset{%
apply style/.code={\tikzset{#1}},
brick_edges/.style={thick,draw=black},
face_coloura/.style={fill=gray!50},
face_colourb/.style={fill=gray!25},
face_colourc/.style={fill=gray!90},
\foreach \theta/\v/\facestyleone/\facestyletwo in {%
0/0/{brick_edges,face_coloura}/{brick_edges,face_colourc},
180/-\a/{brick_edges,face_colourb}/{brick_edges,face_colourc}
\begin{scope}[rotate=\theta,shift={(\v,0)}]
\draw[apply style/.expand once=\facestyleone]
({-.5*\b},{1.5*\a}) --
++(\b,0) --
++(-\a,-\a) --
++({-\b+2*\a},0) --
++(0,-{2*\a}) --
++(\b,0) --
++(-\a,-\a) --
++(-\b,0) --
cycle;
\draw[apply style/.expand once=\facestyletwo]
({.5*\b},{1.5*\a}) --
++(0,{-2*\a}) --
++(-\a,0) --
++(0,\a) --
cycle;
\end{scope}
\end{tikzpicture}
Penrose Triangle:
\begin{tikzpicture}[scale=1, line join=bevel]
% dimensions of the Penrose triangle.
\pgfmathsetmacro{\a}{2.5}
\pgfmathsetmacro{\b}{0.9}
\tikzset{%
apply style/.code = {\tikzset{#1}},
triangle_edges/.style = {thick,draw=black}
\foreach \theta/\facestyle in {%
0/{triangle_edges, fill = gray!50},
120/{triangle_edges, fill = gray!25},
240/{triangle_edges, fill = gray!90}%
\begin{scope}[rotate=\theta]
\draw[apply style/.expand once=\facestyle]
({-sqrt(3)/2*\a},{-0.5*\a}) --
++(-\b,0) --
({0.5*\b},{\a+3*sqrt(3)/2*\b}) -- % higher point
({sqrt(3)/2*\a+2.5*\b},{-.5*\a-sqrt(3)/2*\b}) -- % rightmost point
++({-.5*\b},-{sqrt(3)/2*\b}) -- % lower point
({0.5*\b},{\a+sqrt(3)/2*\b}) --
cycle;
\end{scope}
\end{tikzpicture}
The electric dipole moment (p) in the water molecule
\begin{tikzpicture}[>=latex,scale=1.3]
\shade[ball color=gray!10!] (0,0) coordinate(Hp) circle (.9) ;
\shade[ball color=gray!10!] (2,-1.53) coordinate(O) circle (1.62) ;
\shade[ball color=gray!10!] (4,0) coordinate(Hm) circle (.9) ;
\draw[thick,dashed] (0,0) -- (2,-1.53) -- (4,0) ;
\draw[thick] (2,.2) -- (2,1.5) node
{$\mathbf{p}$} ;
\draw (2.48,-1.2) arc (33:142:.6) ;
\draw (2,-.95) node[above]{$105^{\circ}$} ;
\draw (0,.2) node
{H$^+$} ;
\draw (4,.2) node
{H$^-$} ;
\draw (2,-1.63) node[below]{O$^{2-}$} ;
\foreach \point in {O,Hp,Hm}
\fill [black] (\point) circle (2pt) ;
\end{tikzpicture}​
Parallel lines and related angles
\begin{tikzpicture}
\draw[fill=yellow] (0,0) -- (60:.75cm) arc (60:180:.75cm);
\draw(120:0.4cm) node {$\alpha$};
\draw[fill=green!30] (0,0) -- (right:.75cm) arc (0:60:.75cm);
\draw(30:0.5cm) node {$\beta$};
\begin{scope}[shift={(60:2cm)}]
\draw[fill=green!30] (0,0) -- (180:.75cm) arc (180:240:.75cm);
\draw (30:-0.5cm) node {$\gamma$};
\draw[fill=yellow] (0,0) -- (240:.75cm) arc (240:360:.75cm);
\draw (-60:0.4cm) node {$\delta$};
\end{scope}
\begin{scope}[thick]
\draw (60:-1cm) node[fill=white] {$E$} -- (60:3cm) node[fill=white] {$F$};
\draw[red] (-2,0) node
{$A$} -- (3,0)
node
{$B$};
\draw[blue,shift={(60:2cm)}] (-3,0) node
{$C$} -- (2,0)
node
{$D$};
\draw[shift={(60:1cm)},xshift=4cm]
node [right,text width=6cm,rounded corners,fill=red!20,inner sep=1ex]
When we assume that $\color{red}AB$ and $\color{blue}CD$ are
parallel, I.\,e., ${\color{red}AB} \mathbin{\|} \color{blue}CD$,
then $\alpha = \delta$ and $\beta = \gamma$.
\end{scope}
\end{tikzpicture}
Intersection of
\begin{tikzpicture}
%preamble \usetikzlibrary{arrows}
scale=5,
axis/.style={very thick, ->, >=stealth'},
important line/.style={thick},
dashed line/.style={dashed, thin},
pile/.style={thick, ->, >=stealth', shorten <=2pt, shorten
>=2pt},
every node/.style={color=black}
% axis
\draw[axis] (-0.1,0) -- (1.1,0) node(xline)
{$G\uparrow/T\downarrow$};
\draw[axis] (0,-0.1) -- (0,1.1) node(yline)[above] {$E$};
% Lines
coordinate (B) node[right, text width=5em] {$Y^O$};
coordinate (D) node[right, text width=5em] {$\mathit{NX}=x$};
% Intersection of lines
\fill[red] (intersection cs:
first line={(A) -- (B)},
second line={(C) -- (D)}) coordinate (E) circle (.4pt)
node[above,] {$A$};
% The E point is placed more or less randomly
\fill[red] (E) +(-.075cm,-.2cm) coordinate (out) circle (.4pt)
node[below left] {$B$};
% Line connecting out and ext balances
\draw [pile] (out) -- (intersection of A--B and out--[shift={(0:1pt)}]out)
coordinate (extbal);
\fill[red] (extbal) circle (.4pt) node[above] {$C$};
% line connecting out and int balances
\draw [pile] (out) -- (intersection of C--D and out--[shift={(0:1pt)}]out)
coordinate (intbal);
\fill[red] (intbal) circle (.4pt) node[above] {$D$};
% line between out og all balanced out :)
\draw[pile] (out) -- (E);
\end{tikzpicture}
Intersecting lines
\begin{tikzpicture}[scale=1.5]
% Draw axes
\draw [<->,thick] (0,2) node (yaxis) [above] {$y$}
|- (3,0) node (xaxis)
{$x$};
% Draw two intersecting lines
\draw (0,0) coordinate (a_1) -- (2,1.8) coordinate (a_2);
\draw (0,1.5) coordinate (b_1) -- (2.5,0) coordinate (b_2);
% Calculate the intersection of the lines a_1 -- a_2 and b_1 -- b_2
% and store the coordinate in c.
\coordinate (c) at (intersection of a_1--a_2 and b_1--b_2);
% Draw lines indicating intersection with y and x axis. Here we use
% the perpendicular coordinate system
\draw[dashed] (yaxis |- c) node
{$y'$}
-| (xaxis -| c) node[below] {$x'$};
% Draw a dot to indicate intersection point
\fill[red] (c) circle (2pt);
\end{tikzpicture}​
1. What is TikZ?
TikZ is a powerful and popular package for creating high-quality graphics and diagrams in LaTeX. It stands for "TikZ ist kein Zeichenprogramm" which translates to "TikZ is not a drawing program" in English.
2. What are TikZ templates?
TikZ templates are pre-defined, reusable designs and layouts that can be used to create diagrams and illustrations. These templates save time and effort by providing a starting point for creating complex graphics.
3. How do I use TikZ templates?
To use a TikZ template, you first need to have the TikZ package installed in your LaTeX editor. Then, you can copy and paste the template code into your document and modify it as needed. Alternatively, you can create your own template by saving a TikZ code snippet as a template file.
4. Are there any examples of TikZ templates?
Yes, there are numerous examples of TikZ templates available online. Many LaTeX forums and websites offer free templates for users to download and use in their documents. Additionally, the official TikZ package documentation also includes several examples of templates.
5. Can I customize TikZ templates?
Yes, TikZ templates are highly customizable. You can modify the colors, shapes, sizes, and other elements of a template to suit your needs. You can also combine multiple templates or create your own unique template by combining different elements from existing templates.
  • Feedback and Announcements
  • Poll
  • General Math
