Time Average Value of Pendulum String Tension
34 replies · 5K views · last reply
Staff Emeritus
Homework Helper
Insights Author
2025 Award
Another member and I, in private conversations, have been discussing the time average tension in a pendulum string. He has done a numerical analysis of the problem, and his calculations indicate that the time average tension is less than mg. I have analyzed the problem analytically by expanding in the maximum angle ##\theta_0## for small values of this angle and found that the time average tension, at least for small maximum angles, is ##mg\left(1+\left(\frac{\theta_0}{2}\right)^2\right)##; so my analysis suggests that the time average tension is greater than mg. I'd like to give other members a chance to weigh in on this.
The parameters are: string length = L, mass = m, maximum angle with vertical = ##\theta_0##.
Chestermiller said:
maximum angle with vertical = θ
Surely that is the most critical parameter. At 90 degrees, the downward force is zero. With more than 90 degrees, it is negative. You analyzed it for small angles only. Might your friend have included larger angles?
My understanding is he solved it for a range of maximum angles.
For the average to make sense, it must be over a full swing which then can be taken over half a swing by symmetry. Using a free body diagram and energy conservation you can show that the tension is given by $$T=3mg(\cos\theta -\cos\theta_0)$$ Then $$T_{\text{avg.}}=\frac{3mg\int_{-\theta_0}^{\theta_0}(\cos\theta -\cos\theta_0)d\theta}{\int_{-\theta_0}^{\theta_0} d\theta}.$$I don't have time to finish it now and plot it as a function of ##\theta_0##, but it should be easy to do.
The time average of the vector tension over a cycle has got to be mg up, yes?
The other member and I both got $$T=mg(3\cos\theta -2\cos\theta_0)$$
Also, I said the time average not the average with respect to ##\theta##.
Also, we were referring the time average of the magnitude of the tension.
Yes. The vector average must be ##mg## up. I believe that in general the magnitude of the vector average will always be less than the average of the vector magnitude.
I think that true for the average of the square of the vector but the time average of the magnitude is not the sqrt of the time average of the magnitude squared. That was the wall I hit.
Agreed, but I think that the triangle inequality still holds.
Yes. But that's also where it is going fast. For larger theta as @anorlunda pointed out there will be a place where it can be less and it will spend more time there...so I'm not sure.
But clearly for small enough oscillations your result should hold for the cycle I think.
The average with respect to theta is greater than mg, and increases with maximum angle; the approximation I derived for small angle agrees very closely with the exact average (wr theta) up to max angles of 45 degrees.
I stand corrected. I impulsively thought that the pendulum can act as the time clock, but it can't.
The average with respect to theta is $$\frac{\bar{F}}{mg}=3\frac{\sin{\theta_0}}{\theta_0}-2\cos{\theta_0}$$which, at small values of ##\theta_0## becomes: $$\frac{\bar{F}}{mg}=1+\frac{\theta_0^2}{2}$$
At 30 degrees, the exact rhs is 1.13, compared to 1.14 from the approximation.
At 45 degrees, the exact rhs is 1.29, compared to 1.31 from the approximation.
The only question is whether the shorter residence times at smaller angles than at larger angles characteristic with time averaging is enough to reverse the effect.
Based on the methodology in the following video,
I got the exact analytic solution for the time average tension in the string. This was based on the non-linear equation for the angular velocity:
$$\frac{d\theta}{dt}=\sqrt{\frac{2g}{L}}\sqrt{\cos{\theta}-\cos{\theta_0}}$$
My final result for the time average tension was $$\frac{\bar{F}}{mg}=3\left[2\frac{K(\sin{(\theta_0/2}))}{E(\sin{(\theta_0/2}))}-1\right]-2\cos{\theta_0}$$ where K and E are the first and second complete elliptic integral functions, respectively.
For a maximum angle of 30 degrees, I get 1.069 mg, compared to 1.069 mg from my approximate solution.
For a maximum angle of 60 degrees, I got 1.223 mg, compared to 1.274 mg from my approximate solution.
So I threw this into Mathematica to see what it says. I used the non-approximate differential equation:
$$\ddot \theta + \frac{g}{L} \sin(\theta) = 0$$ and the equation for the tension $$T=mg \cos(\theta)+ m (L \dot \theta)^2/L$$
I solved the differential equation with Mathematica and got $$\theta(t)=2 \text{am}\left(\frac{\dot \theta_0 t}{2},\frac{4g}{\dot \theta_0^2 L}\right)$$ where ##\theta (0)=0## and ##\dot \theta(0)=\dot \theta_0## and where ##\text{am}## is the Jacobi Amplitude function. I found it easier to parameterize by measuring ##t=0## when ##\theta=0## so that I could easily find the period using the "FindRoot" function. I used FindRoot to find ##t_f##, the time that the first period ends. Then I calculate the normalized average tension by $$\bar T = \frac{1}{mg t_f}\int_0^{t_f} |T| dt$$
In all of the below I used ##g=9.8## and ##L=m=1## and I varied ##\dot \theta_0##.
For ##\dot \theta_0=1## we see a nice approximately simple harmonic motion, with a period of ##t_f=2.02## and ##\bar T = 1.025##
Plot of a periodic curve oscillating between about -0.32 and 0.32 over horizontal time values from 0 to about 4.8, with peaks near 0.5, 2.5 and 4.5.
For ##\dot \theta_0=6.1## we clearly see the expected noticeable deviation from simple harmonic motion, with a period of ##t_f=3.71## and ##\bar T = 1.606##
Plot of theta(t) against t for a pendulum, a smooth sinusoid-like curve starting at 0 near t=0, peaking near 2.7 around t=1, crossing zero near t=1.9, reaching a minimum near -2.7 around t=2.8, and returning to zero near t=3.8; y-axis ticks at -2, -1, 1, 2, 3; x-axis ticks 1 to 5.
I also got 1.07 for ##\dot \theta_0=1.620## which gets pretty close to 30 deg peak
I also got 1.223 for ##\dot \theta_0 = 3.13## which gets pretty close to 60 deg peak
Really nice work Dale! You're the man.
Thanks very much.
Chet
If it were not mg'up' the mean position of the pendulum would have to be changing (up, down or sideways). That's Newton 1.
However, the long way round, due to @Dale and others is, of course, valid and it's a relief that both ways give the same answer.
Before concluding this thread, I thought it would be worthwhile showing the method I used to arrive at the analytic solution for the time averaged tension. The important feature is that the method did not actually require solving for the time variation of the pendulum angle.
The time average of the tension is given by: $$\bar{F}=\frac{\int_0^{T/4}{F(t)dt}}{(T/4)}$$where T is the period. In addition, we have that the angular velocity of the pendulum is expressed entirely as a function ##f(\theta)## of the pendulum angle ##\theta## as:$$\frac{d\theta}{dt}=\sqrt{\frac{2g}{L}}\sqrt{\cos{\theta}-\cos{\theta_0}}=f(\theta)$$Therefore, we can write $$dt=\frac{d\theta}{f(\theta)}$$where t runs from 0 to T/4 as ##\theta## runs from 0 to ##\theta_0##. In addition to this, we already know the tension as a function of ##\theta## as:$$F(\theta)=mg(3\cos\theta -2\cos\theta_0)$$Therefore, we can write: $$\bar{F}=\frac{\int_0^{\theta_0}{\frac{F(\theta)}{f(\theta)}d\theta}}{\int_0^{\theta_0}{\frac{d\theta}{f(\theta)}}}=mg\frac{\int_0^{\theta_0}{\frac{(3\cos\theta -2\cos\theta_0)}{\sqrt{\cos{\theta}-\cos{\theta_0}}}d\theta}}{\int_0^{\theta_0}{\frac{d\theta}{\sqrt{\cos{\theta}-\cos{\theta_0}}}}}$$
These integrals are evaluated analytically using the methods discussed in the video.
And if you substitute that exact result into WolframAlpha, it spits out a series expansion which matches your result in the first post.
Nice talk. He told everything except for the sole that should have been told: the phase portrait.
Sorry for offtop
I tried to use a spreadsheet for numerical analysis. A total of 20,000 calculation steps were used, but my computer only took less than a second to complete the calculation.
When the maximum angle is 60 degrees, I found that the average tension is 1.223 mg, which is greater than 1.
Excel spreadsheet of a pendulum simulation with three line graphs: angular velocity, angular position in radians, and tension in mg, plus a cell showing average tension 1.223.
It just goes to show how processor-intensive modern video games are. That is probably the highest demand from most domestic users. A few simple 'sums' are no trouble for your PC, even though a spreadsheet plods through those things using interpretive routines without the help of a compiled language.
Because I haven't used this kind of numerical analysis for a long time, there are many imperfections in the calculations I uploaded before.
By averaging only a quarter period and other optimization measures, I now improve the efficiency of the calculation method, as shown below
1. The time interval can be increased from 0.1 ms to 1.0 ms
2. The number of iterations dropped sharply from 20000 to only about 1000
Please note that the calculation result only increased from 1.223 to 1.224, with an error of less than 0.1%, which really surprised me.
I used the second-order Runge–Kutta method, if anyone is interested, you can refer to this link
https://en.wikipedia.org/wiki/Runge–Kutta_methods
Spreadsheet with pendulum parameters and three plots: angular velocity, angular position and tension (mg) against time, and an average tension value of 1.224.
I think you can discretise the SHM into horizontal and vertical components.
I struggle to imagine the average of the vertical is not mg? There is no net work being done. Just a consideration of 'energy' puts that one to bed, doesn't it? Am I under-thinking that one?
The horizontal should be quite easy to work out, equation of SHM within a given displacement and a given period.
So total tension will always be the quadrature sum of the vertical (average mg) plus the horizontal restoring SHM force.
I think? No more complicated than that?
Isn’t it obvious that the mean force has to be mg or 1. The string would have to be changing length or 2. The suspension point would have to be moving.
If not, I think we could be into a reactionless drive system.
It is obvious. But they are calculating the mean of the magnitude of the force which is larger.
Yes as mentioned in #6 to be sure we were on the same page:
Is there an easy (not involving looking up elliptic functions although that was well done) to answer the original question About time average of T definitively (is it greater than mg) ? Something involving the triangle inequality and positive definiteness? I can't seem to pin it down, and it is niggling at me.
Perhaps the mean is not the right sort of 'average' to be using. The appropriate 'rules' for vectors need to be followed if the result of a calculation is to be meaningful. N1 has to be followed.
That triangle inequality must be the relevant factor, I think.
(A1 + A2)2 + (B1 + B2)2 is not equal to
A12+A22+B12+B22
Bad notation but it shows what I mean. It agrees with @Dale way back in the thread.
