Time Dilation and the Flawed World Record Attempt: A Physics Explanation
anxmetal
An athlete has learned enough physics to know that if he measures from the Earth a time interval on a moving spacecraft , what he finds will be greater than what somebody on the spacecraft would measure. He therefore proposes to set a world record for the 100m dash by having his time taken by an observer on a moving spacecraft . Is this a good idea?
My Answer: No, because the observer in the spacecraft would measure a longer time interval not a shorter time interval. Can anyone explain it further?
Not a good idea as the judge on the moving spacecraft would see the track as moving and therefore contracted in Length so the athlete would not have run the full 100 metres. How much contracted I hear you ask well exactly what is required to keep the speed of light constant. The time is reduced by a factor of sqrt (1-v^2/c^2) and the length of the track by the same factor (V being the velocity of the judge with respect to the track and c being the speed of light in vacuum)
According to the person on earth, a clock on the spaceship ticks slowly and according to a person on the spaceship, a clock on the Earth ticks slowly (not including the affects of gravity).
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
