Time Earth reached its Perihelion
  • Thread starter Thread starter Philosophaie
    Earth Time
On January 4, 2012, the Earth reached its perihelion, marking its closest point to the Sun in its elliptical orbit. There are conflicting reports regarding the exact time of this event, with sources citing times ranging from 10:59 PM EST on January 4 to 00:33 TT on January 5. The discrepancies arise from different models used, such as the Earth-Moon barycenter versus the Earth itself. The JPL Horizons data indicates that the perihelion occurs when the Earth-Sun range rate shifts from negative to positive. Ultimately, the timing of perihelion should not be overly scrutinized down to the second.
Philosophaie
On 1-4-12 the Earth reached its Perihelion.
It is the closest Earth's radius to the Sun in its ellipse.
I have a few sources that have conflicting accounts about the TIME this happened.
Could someone give me a definitive source to clarify my discrepancies of clock differences.
One said 1-4-12 @10:59PM EST, other varied from 0:00Mid to 6:00AM that same day.
Astronomy news on Phys.org
January 5, 2012 at 00:33 (TT).
Do you mean January 5, 2012 @00:00:33TT which translate to Ephemeris Time Jan 5, 2012 @00:00:0.816ET?
No, I meant 33 minutes after midnight (TT), just as I typed it. That is the time at which Earth-Sun range rate went from negative to positive per JPL Horizons. I wouldn't put too much stock in timing this down to the second.
From the Barycenter Earth-Moon model in JPL Horizons with @sun as the center. The smallest Helio range "r" and the Helio rate changing positive has a date of January 4,2012 @3:00(TT). Why is it different to your perihelion of January 5, 2012 at 00:33 (TT)?
You used the Earth-Moon barycenter. I used the Earth. Earth perihelion passage is the time at which the Earth is closest to the Sun, not the Earth-Moon barycenter.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
Today at about 4:30 am I saw the conjunction of Venus and Jupiter, where they were about the width of the full moon, or one half degree apart. Did anyone else see it? Edit: The moon is 2,200 miles in diameter and at a distance of 240,000 miles. Thereby it subtends an angle in radians of 2,200/240,000=.01 (approximately). With pi radians being 180 degrees, one radian is 57.3 degrees, so that .01 radians is about .50 degrees (angle subtended by the moon). (.57 to be more exact, but with...
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
