Good Tips to Solve Non-Linear ODE
  • Thread starter Thread starter JoPe
    Tips
JoPe
Hi!
I am trying to demonstrate a solver for non-linear ODE an wonder if anyone has got a tip on one which is non-trivial to solve, and has some significance to some people so that maybe someone will read my report =)
If you got a good tip, thank you very much!
How about this Riccati equation:
y^{\prime} + y^2 + \alpha(x) = 0
(where alpha is an arbitrary function of x, and y = y(x) as well). This has no general solution (as far as I know) -- and it is very important. If you can provide an analytic solution to this, then fame and fortune is yours. ;-)
Thank you, i will look into that one. Although it is not an analytical solution i am working with, but a numerical. If i am not mistaking the analytical method for solving them are already known?
Sorry, I misunderstood -- the equation I quoted has no known general solution (analytical), but I suspect there are many numerical methods already associated with it. If you apply your method, you should then do a survey on the web of other numerical techniques applied this class of equations, and then compare results.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
