Titration of a triprotic acid with strong base NaOH
The discussion centers on calculating the molar mass of an unknown triprotic acid titrated with NaOH. A 0.307g sample of the acid is titrated using 35.2 mL of 0.106 M NaOH, leading to confusion about the calculation process. Participants clarify that the number of moles of NaOH should be calculated rather than converting to grams, emphasizing the importance of understanding the equivalence point in the context of a triprotic acid. The correct approach involves using the moles of NaOH to determine the moles of acid and subsequently its molar mass. The discussion highlights the need for accurate calculations and comprehension of titration concepts.
xpatelsxownage
A 0.307g sample of an unknown triprotic acid is titrated to its equivilence point using 35.2ml of 0.106 M NaOH. Calculate the molar mass of the acid. Answer is in g/mole.
I just don't know where to start with this question.
35.2 ml * 1L/1000ml * .106M NaOH/1L * 39.9969gNaOH/1mole NaOH = 120.430 g NaOH
I don't know where to go after this part
Not "Its" equivalence point; WHICH equivalence point? The first, second, or third? The question is about a triprotic acid.
You don't need to calculate the number of grams of NaOH (which you did incorrectly). You set it up right but probably entered it in your calculator incorrectly. You should have gotten something like 0.149 g NaOH if this was what the question asked, which it wasn't.
Why don't you calculate the number of moles of NaOH used and find a relationship between that and the number of moles of triprotic acid. Once you have that, you will have the number of moles of acid and the mass. From that you can calculate formula weight.
It should equal to .149g NaOH
then I think you just subtract from the total.
yaho8888 said:
...then I think you just subtract from the total.
no, nope, nein, nyet.
A 0.307-g sample of an unknown triprotic acid is titrated to the third equivalence point using 35.2 mL of 0.106 M NaOH. Calculate the molar mass of the acid.
What if the problem is to the Third equivalence point?
