Is (x + a + b)^7 - x^7 - a^7 - b^7 Divisible by x^2 + (a + b)x + ab?
  • Thread starter Thread starter Hyperreality
    Theorem
The problem of determining if (x + a + b)^7 - x^7 - a^7 - b^7 is divisible by x^2 + (a + b)x + ab is approached by recognizing that the factors of the divisor are (x + a) and (x + b). To prove divisibility, it is necessary to show that the expression is divisible by both factors. A suggested method involves rewriting terms and simplifying the expression. While the task may seem daunting due to the complexity of expanding a trinomial to the seventh power, it is emphasized that a systematic approach can yield results. Ultimately, the problem is solvable with careful manipulation of the algebraic expressions involved.
Hyperreality
My maths teacher says this problem is not as impossible as it seems, but I just can't solve it.
Show that (x + a + b)^7 - x^7 - a^7 - b^7 is divisble by
x^2 + (a + b)x +ab.
Mathematics news on Phys.org
Looking for the easy way out huh ?
You can always solve the entire excercise...
Live long and prosper.
Show that (x + a + b)^7 - x^7 - a^7 - b^7 is divisble by x^2 + (a + b)x +ab.
Hint:
Notice that (x+a) and (x+b) are the 2 factors of x^2 + (a + b)x +ab.
So it is equivalent to show that (x + a + b)^7 - x^7 - a^7 - b^7 is divisible by both (x+a) and (x+b).
Let f(x) = (x + a + b)^7 - x^7 - a^7 - b^7
Can you continue from here?
Hope this help. :smile:
just write everything out
eg. (x+a)^2=x^2+2xa+a^2
maybe rewrite some terms then and you will see that it is divisible by x^2 + (a + b)x +ab
KL has the easy way!
Writing it out however... *shudder* I wouldn't wish writing out a trinomial to the 7th power to anyone!
Hurkyl
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
