Moivre-Laplace theorem (homework)
The discussion revolves around using the normal approximation to compute the probability of successes in Bernoulli trials. The user initially misinterprets the absolute value condition, leading to an incorrect compound inequality. Clarifications emphasize that the correct interpretation involves determining the conditions for S(n) being greater than 9 or less than 5. The importance of applying a continuity correction for better accuracy in the approximation is highlighted. Ultimately, the user expresses gratitude for the guidance received in resolving their confusion.
Poetria
< Mentor Note -- thread moved to HH from the technical math forums, so no HH Template is shown >[/color]
I have no idea what I am doing wrong. Here is my problem:
S(n) - the number of successes in 10 Bernoulli trials, each with probability 0.7
I am supposed to use normal approximation to compute :
P{|S(n)/10-0.7|>0.2}
We are allowed to use a calculator.
I got:
|S(n)-7|>2|
5<S(n)>9
I have computed S*:
S(n)-7/1.44914
7=mean
1.44914- standard deviation
5*1.44914-7<Z<9*1.44914-7
Area (probability): 0.2451
But there is no such answer in the options.
I got:
|S(n)-7|>2|
5<S(n)>9
I have computed S*:
S(n)-7/1.44914
7=mean
What do you mean by 5<S(n)>9 ?
That's an invalid compound inequality.
Likes Poetria
I see. :( My line of thought was as follows:
S(n)-7>2 or S(n)-7<-2 (this is an absolute value equation: |S(n)/10-0.7|>0.2)
How to correct it?
How to correct it?
What you have here is correct.
That says S(n) > 9 or S(n) < 5 . (You had S(n) > 5 )
You can't make these into a compound inequality.
I got:
|S(n)-7|>2|
5<S(n)>9
I have computed S*:
S(n)-7/1.44914
Wrong: use parentheses, like this: (S(n) - 7)/1.44914
7=mean
Wrong: you need 5 > 7 + 1.44914*Z or 7 + 1.44914*Z > 9
The complement of the event "{S(n) < 5} or {S(n) > 9}" is {5 <= S(n) <= 9}, which translates to
5 <= 7 + 1.44914*Z <= 9, or -1.38 <= Z <= 1.38 in the normal approximation.
However, since n = 10 is small, the normal approximation might not be very good, but it can be improved a lot by using the so-called "1/2-correction". The random variable S(n) is discrete (taking values 0,1,2,...,10 only), so {5 < S(n) < 9} = {S(n) = 6,7,8}. In the normal approximation, replace this by {5.5 <= S_normal <= 8.5}, so
5.5 <= 7 + 1.44914*Z <= 8.5. The resulting increase in accuracy is striking in this example.
I got:
|S(n)-7|>2|
5<S(n)>9
I have computed S*:
S(n)-7/1.44914
7=mean
Likes Poetria
Thank you so much. I have tried to work it out. I think I got it. My problem is that I still can't get an exact answer. The closest (with the correction you have suggested):
if x = 5.5 I get 0.15031188 (I can choose 0.1675)
http://www.danielsoper.com/statcalc3/calc.aspx?id=53
The result: 0.08377348 is very imprecise.
Actually some calculators demand x, some Z. It is a mess.
Sorry, I get 0.71860226. Even worse.
I got it at last. :) Many thanks. :) You have helped me a lot. :) :) :)
