Topography of spacetime over time.
  • Thread starter Thread starter D.S.Beyer
    Spacetime Time
D.S.Beyer
"Topography" of spacetime over time.
How has spacetime curvature changed since the early universe?
In the beginning, (close to the beginning that is), everything was hydrogen (sort of). That hydrogen was more or less homogeneous save a few little places, that would, after billions of years, would become stars and galaxies.
The spacetime deformation of the homogeneous hydrogen was slight but it was also everywhere. As the hydrogen began its life toward stars and galaxies it condensed in places and receded from other places. And so spacetime deformation 'grew' in places the hydrogen condensed and 'lessened' in areas the hydrogen receded.
What can be said about the gravitational length contraction of these new 'empty' areas? Does the act of condensation of matter lead to areas of both contraction near mass and dilation between the condensing areas? Which would translate visually as the areas of mass moving away from each other, would it not? What Doppler or Red Shift effects does gravitational length contraction and dilation have?
Also can we say that relative to now, here on earth, in the milkyway, that time in the early universe was passing more quickly?
Thoughts?
(Also, I posted this is the cosmology section with VERY little response. In general it seems the people in SR&GR forum are much more helpful, professional, and responsive...relatively. :-P)
Thoughts?
I don't know if you are really asking a question, but the simple answer is that in the VERY early universe, during the inflationary epoch, the universe was highly curved, whereas not it appears to be essentially flat.
In the beginning, when this was relevant, there was no hydrogen.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
