Topology Questions: Isham's Modern Differential Geometry for Physicists
  • Thread starter Thread starter UJS
    Topology
Isham's "Modern Differential Geometry for Physicists" is being used by a physics student as preparation for general relativity, but they are struggling with the introductory chapter on topology. The discussion focuses on the definitions of filters, filter bases, and neighbourhood structures, which are foundational to understanding topological spaces. The student seeks clarification on the implications of a filter base consisting of open sets and how it relates to the generated filter. Key definitions include the concepts of upper sets, boundary points, and the generation of filters from filter bases. Overall, the thread emphasizes the importance of these foundational concepts in grasping the material in Isham's book.
UJS
I'm a physics student and I'm trying to work my way through Isham's Modern differential geometry for physicists. I guess the first question would be what you guys think of this book, does it cover all the necessary stuff (it's my preparation for general relativity)? Sadly I'm already having trouble with the introductory chapter on topology.. I'll post my questions in this topic.
Isham starts out by defining filters and neighbourhood structures on a set X. A topological space is then a special kind of neighbourhood space. The proof of the following theorem is left up to the reader, but this reader needs some pointers..
"A neighbourhood space (X,N) is a topological space if and only if each filter N(x) has a filter base consisting of open sets."
When a filter base consists of open sets, what consequences does that have for the filter it generates?
Mathematics news on Phys.org
You don't have to study differential geometry to prepare for general relativity. The standard books used for both undergrad and grad courses develop the geometry that is needed to understand the theory. It's surprisingly not that much. When you want to study a more advanced treatment of some of the topics in relativity, that book will come in handy.
It would help us if you defined your terms. How are topological spaces defined? Filters? Filter bases? Open sets? etc. etc.
Ok, here are all the definitions that have been used:
The power set P(X) of a set X is a lattice, with A \preceq B defined as A \subset B. Now a subset U of P(X) is an upper set if \forall a,b \in P(x) with a \subset b, a \in U implies b \in U.
A filter F on X is a family of subsets of X such that F is algebraically closed under finite intersections, F is an upper family, and the empty set is not in F.
A filter base D is a family of non-empty subsets of X such that if A,B \in D, then there exists C \in D such that C \subset (A \cap B)
A neighbourhood structure N on X is an assignment of a filter N(x) to each x \in X, all of whose elements contain the point x. The pair (N,X) is then called a neighbourhood space.
Given a neighbourhood space (N,X) and any set A \in X, a point x in X is a boundary point of A if every neighbourhood of x intersects both A and the complement of A (a neighbourhood of x is an element of N(x)). An open set is then a set that contains none of its boundary points.
I suppose "each filter N(x) has a filter base" means that the filters N(x) are generated by those bases. In that case, here's the final definition:
If D is a filter base, then \uparrow(D) := \{B \subset X| \exists A \in D \ such \ that \ A \subset B\} is a filter, which is said to be generated by D.
Edit: forgot one.. A topological space is a neighbourhood space (X,N) in which, for all x in X and for all M in N(x), there exists M_1 \in N(x) such that, for all y \in M_1, M \in N(y).
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
