Torque-Free Precession and Wobble direction
In the discussion on Torque-Free Precession and wobble direction, participants explore whether the wobble of a spinning plate can occur in the same or opposite direction to its spin, particularly when tossed upward or downward. The conversation references Feynman's Wobbling Plate, noting a discrepancy between observed wobble rates and theoretical predictions. It highlights that the wobble-to-spin ratio is influenced by the plate's size and shape, with concerns about how excessive amplitude affects this relationship. The distinction between torque-free precession and pure precession is also clarified, emphasizing different wobble and spin ratios. Overall, the discussion delves into the complexities of rotational dynamics and the conditions influencing wobble behavior.
Dueschnozzle
In Torque-Free Precession of a plate, can the direction of the Wobble be either in the spin direction or retrograde to it?
For instance if you tossed the plate upward vs downward with the same spin direction. Would the wobble direction and frequency be inverse?
Anyone?
I am not sure that understood your question correctly, but anyway you are asking about the Euler top. Try textbooks
Hmm... I was asking more about Feynman's Wobbling Plate. Feynman said he observed the wobble at half the spin rate, but his equation says it's 2 wobbles per spin. Could both be true? From what I've read the wobble to spin ratio is determined by the size and shape, with the caveat as long as the amplitude is not too large. What happens when the amplitude is too large?
yes, it is a special case of the Euler top
So is this the difference between torque free precession = 2 wobble/1retrograde spin, vs roll or pure precession = 1wobble/1spin in same direction or zero spin?
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
