Total Angular Momentum Measurements
3 replies · 2K views
andre220
Consider a particle with orbital momentum ##l=1## and spin ##s = 1/2## to be in the state described by
$$\Psi = \frac{1}{\sqrt{5}}| 1,1\rangle|\downarrow\rangle+\frac{2}{\sqrt{5}}|1,0\rangle|\uparrow\rangle$$
If the total angular momentum is measured what would be the possible outcomes? What are the corresponding probabilities?
##\mathbf{J} = \mathbf{L}+\mathbf{S}##
Okay, so on the surface this seems pretty simple, but I want to make sure that I am not thinking about this wrong.
For the first state: ##J=1-1/2 =1/2## with probability ##1/5## and the second state ##J=1+1/2=3/2## with probability ##4/5##. Is this correct?
No, it's not correct. You need to express the state in terms of eigenstates of ##J^2##.
On second looks, it's not as easy as I thought. For some reason I thought it was ##|j,m\rangle## and instead it is ##|l,m\rangle|s_z\rangle##
What would be a good way to approach this problem? In thinking about it again, I need to determine ##j##, but I am not sure how to go about doing so.
Look up the appropriate Clebsch-Gordon coefficients.
