Tracing Serial EEPROM Pins on a Populated PCB
When tracing pins on a populated PCB with a serial EEPROM chip, continuity tests can yield misleading results due to the presence of components that may introduce parasitic diodes. To verify pin mappings accurately, reversing the DMM terminals can help identify issues caused by these diodes. Another effective technique is to power the board and measure the voltage across the traces, ensuring consistent voltage levels along the path. This method can reveal potential PCB or soldering connection problems. Proper testing techniques are crucial for successful communication with the EEPROM chip.
NPNTransistor
Hello,
I have a simple populated PCB with passive and active elements. The main chip on PCB is a 8 pin serial EEPROM chip which I am trying to read via PIC microcontroller. Serial chip is tiny and hard to solder wires onto so I can send signals from PIC controller to the chip. I will have easier access via traces onto other elements on the board. I am running continuity test to trace pins to other elements but I get beeps on multimeter that seem to suggest incorrect wiring. I doubt my continuity test technique because it is a commercial PCB. What techniques I can use to ensure I am using the correct pin mappings?
Thank you
You can only completely trust a DMM continuity test like this when there are no components installed. Especially with semiconductors (ICs) you can and often do have diodes connected between terminal pins and ground or power (for ESD and OV protections) which can get switched on and appear as a short if you aren't aware of them.
One work-around is to simply reverse the DMM terminals (which reverses the voltage of the test voltage in continuity mode) and see if you still get continuity. For PCB or solder flaws, the direction doesn't matter but for parasitic diodes in ICs it will.
Another work-around is often to have the board powered and simply trace out the expected voltage from one side of the path to the other. If it isn't the same all the way along the path, it indicates a PCB or soldering connection problem.
Thank you.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
