Will the trains ever be at the same distance from the origin?
In summary, two trains, A and B, are traveling towards each other on the same railway line. Train A is initially traveling at a constant velocity of 30m/s while Train B is traveling at a constant velocity of 10m/s. When Train A's driver sees Train B ahead, they immediately start applying the brakes with an acceleration of 1m/s². At the moment the brakes are applied, the distance between the front of Train A and the back of Train B is 200m. The question is whether the trains will collide and if so, where. Using the kinematic equations, it can be determined that the trains will collide when the distance between them is 0, and the time of collision will be
GoodTimes
Train A travels with the velocity v= 30m/s, suddenly the driver sees another train ahead, Train B which travels with the velocity v=10m/s. Immediately Train A's driver starts the brakes ( a=1m/s²) while Train B still travels with its velocity. The moment A starts the brakes the distance between A's front and B's back is 200m.
Will both trains collide? If yes, where?
v1=30m/s
v2=10m/s
a=1m/s²
distance=200m
i searched the internet and found an equation:
s= v² / 2a
I was going to try it this way but ended up being confused. cause i wouldn't get metres out of it, instead seconds
unknown person's attempt
my attempt:
s= 30m/s / 2*1m/s² = 30m/s * 1 / 2m/s²
I don't know how to get a length out of this equation.
Ok I tried another equation
s=1/2 * (deltaV)² / a
s= 1/2 * (30m/s) ² / 1m/s²
s=1/2 * 900m²/s² / 1m/s²
s=1/2 * 900m/ 1
s=450m
is this correct? I would be so glad and happy if it was, usually I feel so dumb since I started university
I calculated that they do collide but i don't know how to calculate where
How do I find out where they collide?
Train A travels 30seconds 450m
during that time Train B travels 150m (+200m) it is less , so they collide.
Maybe you should start by trying to write the kinematic equations for both Train 1 and Train 2 given their velocities in terms of time. Then calculate the difference in distance as
##x_{A} - x_{B}##
The introductory physics equation you are looking for is:
##x(t) = v_{0}t + \frac{1}{2}at^{2}##
where ##x(t)## is the distance, ##t## is the time, ##v_{0}## is the initial velocity, and ##a## is the acceleration.
As an extra hint, you should have two separate equations of the form:
##x_{A}(t) = v_{0,A}t + \frac{1}{2}a_{A}t^{2}##
##x_{B}(t) = v_{0,B}t + \frac{1}{2}a_{B}t^{2}##
##x_{A} - x_{B} = v_{0,A}t + \frac{1}{2}a_{A}t^{2} - v_{0,B}t - \frac{1}{2}a_{B}t^{2}##
But several terms in these equations equal zero (which ones?). It's important to note that you do not know the time of the collision (if there is one), but you can always calculate it using the quadratic formula. The important thing is that if one or both of the two solutions for time may be negative.
##x_{A} - x_{B}##
thanks a lot for helping me
i calculated both and got x_{A} - x_{B} = 600m
is this correct and even possible? cause how are they supposed to collide after 600m if Train A stops completely after 450m?
Ahh...I apologize, I forgot to add one more term to the equations:
##x_{A}(t) = x_{0,A} + v_{0,A}t + \frac{1}{2}a_{A}t^{2}##
##x_{B}(t) = x_{0,B} + v_{0,B}t + \frac{1}{2}a_{B}t^{2}##
We need to take into account the initial displacement between the two trains.
You should get that the trains collide when ##x_{A} - x_{B} = 0## and your time should be an integer number.
I need a bit more help, i don't know what to use as xoa and xob :-(
You choose any convenient point on the railway line to be the point you'll call x = 0. Each train can then be located relative to this point.
You'll then be looking to find whether there is ever a time, t, when the trains are identical distances from that origin.
Xoa and Xob are therefore the distances from the origin of those trains at the start of observations, i.e., at t = 0.
What is a train collision problem?
A train collision problem refers to a situation where two or more trains on the same track collide with each other, resulting in damage to the trains and potentially causing injuries or fatalities.
What are the main causes of train collisions?
The main causes of train collisions include human error, mechanical failures, faulty signals, poor track maintenance, and inadequate communication between train operators and control centers.
How can train collisions be prevented?
To prevent train collisions, safety measures such as speed restrictions, automatic braking systems, and regular maintenance of tracks and trains should be implemented. Proper training and communication protocols for train operators are also crucial in preventing collisions.
What are the consequences of a train collision?
The consequences of a train collision can be severe, including injuries and fatalities to passengers and crew, damage to the trains, and disruption of train services. It can also result in financial losses for the train company and negatively impact the public's trust in train transportation.
What is the role of technology in preventing train collisions?
Technology plays a crucial role in preventing train collisions. Advanced signaling systems, automatic braking systems, and train control systems help to detect and prevent collisions. Additionally, technologies such as GPS and communication systems between trains and control centers can improve the overall safety and efficiency of train operations.
