Transducer Amplifier: Benefits & Use for 0-30mV Output
The discussion focuses on the need for an amplifier for a load cell output of 0-30mV in a data acquisition system that accepts -10 to 10V. While the data acquisition card has a built-in programmable gain instrumentation amplifier, concerns about noise and signal integrity are raised. Participants highlight that dedicated amplifiers can improve signal quality by attenuating noise while amplifying the desired signal. The importance of understanding the load cell's specifications and potential differential output is emphasized for effective integration. Ultimately, the choice between purchasing or building an amplifier depends on the specific application and noise considerations.
james2286
Hi there. I currently have a system that is about to have a load cell installed. The output of the load cell with the 15V excitation voltage will be 0-30mv (2mv/V sensitivity). Now forgive me for asking, as I am not knowledgeable in this area (I have some electronics background, being a Mechatronic engineer, but there are many gaps in my knowledge), but what are the benefits of either buying, or making an amplifier? Our data acquisition card can accept analogue input voltages ranging from -10 to 10V. From reading the manual, it has its own PGIA (programmable gain instrumentation amplifier) that is supposed to dynamically adjust gain so that full resolution is still maintained in the digital conversion. Therefore, my thinking was that if the DAQ card has its own amplifier and resolution is kept intact, that perhaps an amplifier would really be needed?
However I've spoken to a few more people and I heard that you can get amplifiers that attenuates noise while amplifying only the signal? Is this true? In this case would it be beneficial to buy one, or if possible even make one?
Thanks for any help,
Jamie
What is your application? Most transducers I've worked with will provide a means to calibrate and are purchased with a output that is compatible with you acquisition system.
Most of the guys who are doing validation testing on a machine put load cells / strain gauges everywhere and route them to central data acquisition systems. There's a lot that can go wrong with this method. Particularly if you don't have experience bonding strain gauges and electrical noise gets into your system.
Then again, in this case, you have a lot of data to collect, so a Fluke data bucket, or an HP data acq is the way to go.
PC based data acquisition systems tend to be noisier and are more limited in range, so I don't recommend them for sensitive data acq.
For products, such as scales, the cost and performance drives you towards a dedicated solution with an amp. It's much easier to sell the end user a guaranteed stable 0-5 volt output than a hopefully functional -?/+? mV.
- Mike
Your load cell voltage output is almost certainly a differential output, and not referenced to either ground or Vcc (+ 15 volts). So an operational amplifier set up to amplify small differential voltages with a good (high) common mode rejection ratio is essential. We need more detailed information on your specific load cell specifications.
Bob S
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
