Transducing forces through a viscoelastic gel
  • Thread starter Thread starter vbentiv
    Forces
The discussion centers on the use of Matrigel, a biological hydrogel, for exerting forces on cells within small wells. The main inquiry is whether viscoelastic gels can transduce forces effectively, allowing cells inside the gel to "feel" the applied force. The setup involves small wells (1 or 2 mm in diameter) where deformation occurs due to external forces. Observations can be made through optical deformation, which may indicate pressure changes and gel displacement against gravity. The use of individual strain gauges is deemed costly for a 96-well plate, prompting consideration of alternative methods for force measurement. Additionally, the idea of creating wells in a PDMS substrate is proposed, as it may facilitate easier deformation and manipulation of the cells within the Matrigel, which are unable to grow elsewhere.
vbentiv
Hi,
I'm working with Matrigel, a biological hydrogel so to say, and would like to exert forces on something inside the gel. I was wondering, if in general, viscoelastic gels can transduce forces.
Consider the following setup:
Matrigel in small wells (1 or 2 mm in diameter), a force is exerted on this wells (causing them to deform), can something inside the well "feel" this force?
Thanks!
Necessarily inside the well? On exterior, optical deformation could be observed, pressure varying polarization of the plastic. Individual strain gauges would be expensive on a 96-well plate. Optically observe the variation in level if the force displaces the gel against gravity.
I was thinking of making wells in a PDMS substrate for example, which would be more easy to deform than a well plate. And it's cells inside the matrigel (they don't grow anywhere else) that I'd like to manipulate.
