Transfer Function of an unknown device
To find the transfer function of unknown devices like DC and stepper motors, one can utilize a method from the field of System Identification. By applying a fast pulse input to the motor and recording the output response, the impulse response can be obtained. The transfer function can then be derived by taking the Laplace transform of this impulse response. This approach is practical when access to the system's input and output ports is available. Understanding these concepts is essential for effective control of motor velocity in automation projects.
nebbione
Hi everyone, in the last times, I'm really interested in controls engineering, and I wanted toknow how to find transfer functions of devices, or systems in the real world, let me explain better, for example, in my house i have various dc motors, and stepper motors, since i want to make an automatic control of the velocity, I'm blocked since i don't know the trasfer function of the motor... how can i proceed ? How can i find the transfer function of this motor ?
And in general how do i find a transfer function of a system, without knowing the matrixes A,B,C,D ?
What you're asking is non-trivial. The subfield associated with it is called "System Identification".
The easiest thing you can try if you have access to the input and output ports of the system is to input a fast pulse (approximating an impulse) and then record the impulse response. The transfer function would then be the Laplace transform of the impulse response.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
