Transverse Wave Velocity/Acceleration
The discussion centers on calculating the velocity and acceleration of a transverse wave on a stretched cord under specific conditions. The cord has a tension of 90 N, a linear density of 0.08 kg/m, and oscillates with a frequency of 270 Hz and an amplitude of 2.4 cm. The correct velocity at t = 2.2 s for the point at x = 1.30 m is approximately 40.5 m/s, while the acceleration calculation requires maintaining precision in the values of wave number (k), angular frequency (ω), and phase constant (∅) to avoid significant rounding errors.
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with wave mechanics and wave equations
  • Knowledge of angular frequency (ω) and wave number (k)
  • Proficiency in using mathematical software for precise calculations
  • Learn about wave mechanics in detail, focusing on transverse waves
  • Explore the effects of rounding errors in wave calculations
  • Study the use of software like Mathematica for complex wave function calculations
  • Investigate the relationship between wave parameters and their physical implications
Students and educators in physics, particularly those studying wave mechanics, as well as anyone involved in solving problems related to transverse waves and simple harmonic motion.
sbuzsaki
The left-hand end of a long horizontal stretched cord oscillates transversely in SHM with frequency 270 Hz and amplitude 2.4 cm . The cord is under a tension of 90 N and has a linear density 0.08 kg/m . At t=0, the end of the cord has an upward displacement of 2.1 cm and is falling. Consider the point x = 1.30 m on the cord.
(solved A and B)
C. What is its velocity at t = 2.2 s ?
D. What is its acceleration at t = 2.2 s ?
wave velocity v = √(T / μ)
wavelength λ = v/f
wave number k = 2π/λ
ω= 2πf
D(x,t) = Asin( kx - ωt + ∅) for transverse wave traveling to the right
Velocity = -Aωcos(kx - ωt + ∅)
Acceleration = -Aω*ωsin( kx - ωt + ∅)
v = √(T / μ) = √(90/0.08) = 33.54 m/s (rounds to 34 m/s)
λ = v/f = 33.541/ 270 = 0.1242 m
k = 2π/λ = 2π/0.1242 = 50.578 1/m (rounds to 51 1/m)
ω= 2πf = 2π*270 = 1696 1/s (rounds to 1700 1/s)
Plugging things in, D(x,t) = 0.024 sin(51x -1700t + ∅)
(Therefore, part A max velocity is Aω = 0.024 m * 1700 1/s = 40.8 m/s (rounds to 41 m/s)
(Therefore, part B max acceleration is Aω*ω = 0.024*1700*1700 = 69360 m/s^2 (rounds 6.9 *10^4 m/s^2 )
At time t=0, amplitude is 0.021 m, so 0.021 = 0.024 sin(∅), ∅ = 1.06
Full equation: D(x,t) = 0.024 sin(51x -1700t + 1.06)
Velocity (1.30 m, 2.2 s) = -0.024*1700 cos(51*1.3 - 1700(2.2) + 1.06) = 40 m/s
Acceleration (1.30 m, 2.2 s) = -0.024*1700*1700 sin(51*1.3 - 1700(2.2) + 1.06)
Mastering physics says this is wrong (I also tried 41 m/s, thinking maybe there were rounding errors). Given that I got parts A and B correct, I can assume my A and ω are correct, but I can't find anything wrong with my k or ∅. The units work, it's a reasonable order of magnitude given the derived max velocity. I tried entering the equations with the values in terms of their formulas in wolfram alpha, and still wrong! I can't figure out what's wrong! I haven't tried entering my acceleration because my velocity is wrong.
Welcome to PF!
Looks like you plugged in x = 1.03 m instead of 1.30 m.
I wish! That's actually just an error in transcribing my work... Edited now, thanks
With x = 1.30 m I do not get your answer for v.
Yeah, that's where the 40.5 m/s (rounded to 41 m/s) comes in, using wolfram alpha. Are you getting something other than that?
It does seem to be differences in rounding the numbers. If I keep several extra digits in k, ω, and Φ, I get v to be about 27 m/s. It's peculiar that rounding makes this much difference.
Well that does seem to be the correct answer. How bizarre. Thanks much! Could I ask how many you kept, such that acceleration will be correct?
I let Mathematica do the calculations. It keeps quite a lot of digits! But it looks like things settle down if you keep about 6 digits.
Thank you very much! All correct now. At least my theory was right, I guess...
It seems the peculiar behavior is due to the fact that for t = 2.2 s and x = 1.3 m, the argument of the cosine function for the velocity is quite large, about 3665 radians. A 0.1 % change in this argument amounts to almost 4 radians. Thus, the cosine will change a lot with just a small percent change in the argument.
Yes, your work looks good.
