Can You See the Back of Your Vehicle While Traveling at High Velocity?
  • Thread starter Thread starter cody628496
    Velocity
Traveling around an object at high velocity does not allow you to see the back of your vehicle. To achieve this, one would need to exceed the speed of light, which is impossible according to current physics. Regardless of the size of the object, light is always perceived at a constant speed. Thus, even at high speeds, the back of the vehicle remains out of view. The limitations imposed by the speed of light prevent this phenomenon from occurring.
cody628496
Is it possible to travel around an object so fast that you would be able to see the back of the vehicle that you are traveling in? Possibly if the object that you traveled around was small enough?
No. You would have to travel faster than light no matter how small the object.
As the poster above said, it is not possible due to the speed of light.
And you always perceive light at the same speed c, no matter how fast you are traveling .
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
