Husker70
- 89
A 30.0m steel wire and a 20.0m copper wire, both with 1.00mm diameter,
are connected end to end and stretched to a Tension of 150N. How
long does it take a transverse e wave to travel the entire length of
the two wires?
Voulume of Rod = pie r^2(L)
v = sqrrt T/mass per unit length
v = dt/dx
I found the volume of the steel rod to be pie(.0001m)^2(30.0m) = 9.42x10^-7 m^3
I found the volume of the copper rod to be pie(.0001m)^2(20.0m) = 6.42x10^-7 m^3
I looked up the density of steel to be 7850 kg/m^3
I looked up the density of copper to be 8230 kg/m^3
The weight of steel rod should be 9.42x10^-7 m^3/7850 kg/m^3 = 1.2 x 10^-10 kg
Then divide by 30.0m = 4.0x10^-10 kg/m
The weight of copper rod should be 6.28 x 10^-7 m^3/8230 kg/m^3 = 7.63 x 10^-11 kg
Then divide by 20.0m = 3.82 x 10^-12 kg/m
Using V = sqrrt T/mass unit of length
Steel wire is sqrrt 150N/4.0 x 10^-12 kg/m = velocity of steel = 6.12 x 10^6 m/s
Copper wire is sqrrt 150N/3.82 x 10^-12 kg/m = velocity of copper = 3.93 x 10^13 m/s
I added them together amd divided by 2 to get an average of 1.97 x 10^13 m/s
across the whole wire. Then divided that number by 50.0m to get 3.93 x 10^11s
I know that isn't right as the answer is .329s
I'm not sure what I'm doing wrong. Any help would be appreciated.
Thanks,
Kevin
