Why Does Traverse-Time Depend on n Being Odd or Even in Polar Coordinates?
  • Thread starter Thread starter Nikitin
The discussion focuses on the traversal behavior of the polar function r=cos(n*θ) based on whether n is odd or even. When n is even, the function completes its traversal as θ ranges from 0 to 2π, resulting in 2n lobes, while for odd n, it traverses from 0 to π, yielding n lobes. This behavior is attributed to the sign of cos(nθ); when negative, r is interpreted as positive with an added π to θ, causing overlapping lobes in odd cases. The participants seek to understand this dependency and confirm that the function is fully traversed when r returns to its starting point. Examples of r=5cos(4θ) and r=5cos(5θ) are requested to illustrate these concepts.
Nikitin
I have the function in polar coordinates r=cos(n*θ), where r is the radii. I'm supposed to draw the graph of this function, and calculate the area. But to calculate the area, I need to know how fast the function traverses. From the solution in my book, it says if n is even, the function traverses when θ goes from 0 to 2pi, and from 0 to pi if n is odd.
Why is the traverse-time for this function only dependant on if n is odd or even? I do not understand this at all. Can you guys help me develop an intuition for functions in polar coordinates?
Mathematics news on Phys.org
You will cover one lobe as r goes from 0 to 1 and back to 0. That is, as n\theta goes form -\pi+ 2k\pi to \pi/2+ 2k\pi for integer k.
The reason for the "if n is even, the function traverses when θ goes from 0 to 2pi, and from 0 to pi if n is odd." is that when cos(n\theta) is negative, r is negative and, because r is alwas positive in polar coordinates, is interpreted as positive but with \pi added to \theta. When n is odd, that results in one lobe covering another. When n is even, there are 2n lobes, when n is odd there are n lobes.
So you're saying when r goes from 0 to 1 to 0 (and n*θ goes from -pi/2 to pi/2) the function has fully traversed?
Is this a general rule? That when r goes back to where it started, the function has traversed?
is that when cos(nθ) is negative, r is negative and, because r is alwas positive in polar coordinates, is interpreted as positive but with π added to θ. When n is odd, that results in one lobe covering another. When n is even, there are 2n lobes, when n is odd there are n lobes.
I think I get you, but can you please provide an example?
The first graph is r= 5cos(4\theta) and the second graph is r= 5cos(5\theta)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
