Tricky spring problem. Amplitudes and AccelerationMax
A block with a mass of 6.7 kg stretches a vertical spring by 0.26 m when in equilibrium and is then pushed downward at 4.7 m/s, leading to oscillation. The calculated spring constant (K) is approximately 252.54, and the oscillation frequency (omega) is about 0.98. The amplitude of the oscillation is determined to be 0.7655 m. To find the speed of the block after 0.4 seconds, the velocity equation involving angular frequency and amplitude is used. The discussion also touches on the relationship between acceleration and the spring's properties, emphasizing the importance of using correct formulas for oscillatory motion.
yigh
A block with mass m =6.7 kg is hung from a vertical spring. When the mass hangs in equilibrium, the spring stretches x = 0.26 m. While at this equilibrium position, the mass is then given an initial push downward at v = 4.7 m/s. The block oscillates on the spring without friction.
3)After t = 0.4 s what is the speed of the block?
4)What is the magnitude of the maximum acceleration of the block?
Calculated K = 252.5384615
Oscillation Frequency (omega) = .9771168341
Amplitude = vMax*sqrt(m/k)
I got amplitude to be 0.7655.
I used -(omega)*Acos(omega*t) to find V for number 3. I used aMax = omega^2*t
I believe there is an equation that you use to find the velocity at any given point given amplitude, stretched distance, k and mass. hold on... so its the sqrt(k/m) times the sqrt(amplitude^2 - stretched or compressed distance^2) use that
oh nevemind. use 9.8m/s^2(t) to find the speed after sometime. isn't the acceleration the same?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
