Trig Function Limit: Solving lim x->0 sin4x/2x
jog511
lim x->0 sin4x/2x
lim x->0 sinx/x =1
can I write lim x->0 sin4x/2x as sinx/x * 4/2 = 1*2 or am I missing a step ?
jog511 said:
lim x->0 sin4x/2x
lim x->0 sinx/x =1
]No, one cannot do that. There is no rule that says one can pull out a factor from a trig function like this. You have to rewrite you expression in the form
\lim_{y \rightarrow 0} \, C \frac{\sin(y)}{y} where C is some constant and y is something that depends on x, y=y(x). Then this limit will simply give C.
So what you have to do is to identify what choice of y(x) will bring your limit in the form I just described.
like 4/4
jog511 said:
like 4/4
I have no idea what you mean by that. But surely you know that sin(2x) is NOT equal to 2sin(x)?
jog511 said:
like 4/4
Set aside the limit for now. Try writing the expression in the form C \, \sin(y)/y. What is y(x)? What is C?
sin4x/2x * 4/4 = 4*sin4x/4*2x
You haven't answered nrqed's questions.
I'll have to get back to the forum on this
C = 4,
y(x) = 4x
jog511 said:
C = 4,
y(x) = 4x
Well, if you write C \sin(y)/y using what you just wrote here, do you get the function that was given in the question?
I believe I get sin4x/4x
I don't understand this concept. Even Calculus by Larson does not explain it well.
Hold on. If y =4x and C = 4 then
C \sin(y)/y = 4 \frac{ \sin(4x) }{4x}
right? This is not the initial expression.
You need the form
C \frac{\sin(4x)}{4x} WHat is the constant C equal to?
The key point is that we do not know the limit of \frac{\sin(4x)}{2x } but we do know how to take the limit of \frac{\sin(4x)}{4x} So you need to rewrite your initial function in the form
\text{ constant } \times \frac{\sin(4x)}{4x} Then you will be able to take the limit.
c in the original equation was 1
What I meant is that we must write
\frac{sin(4x)}{2x} = C \frac{\sin(4x)}{4x}
What is the value of C?
It has to be 2
jog511 said:
It has to be 2
Correct.
So you have shown that the initial function may be written as
2 \frac{\sin(4x)}{4x}
which, defining y = 4x, may be written as
2 \frac{\sin(y)}{y}
Now, when x goes to zero, y also goes to zero so you are all set to take the limit.
the limit is 2.
thanks for your patience
You are very welcome! :-)
Likes 1 person
it would be 2/2
nevermind i see what you did.
Define the function h(x) as: h(x)=\frac{sin(4x)}{2x}
Try to evaluate this function at zero (i.e. f(0) = ?). You will obtain:
f(0)=\frac{sin(0)}{0}
f(0)=\frac{0}{0}
→ if a function comes out to be "0/0" we call this "indeterminate form", which means that we can use L'Hopital's rule for this limit.
L'Hopital's rule states that:
<br /> \lim_{x\rightarrow a} {\frac{f(x)}{g(x)}} = \lim_{x\rightarrow a} {\frac{f&#039;(x)}{g&#039;(x)}}<br />
So our original problem of:
<br /> \lim_{x\rightarrow 0} {\frac{sin(4x)}{2x}}<br />
is really equal to:
<br /> \lim_{x\rightarrow 0} {\frac{4cos(4x)}{2}}<br />
NOW if we define our new function h(x) as: h(x)=\frac{4cos(4x)}{2}
and evaluate this new function at zero, we will obtain the limit.
h(0)=\frac{4cos(0)}{2}
⇔ h(0)=\frac{4*1}{2}
⇔ h(0)=2
∴<br /> \lim_{x\rightarrow 0} {\frac{sin(4x)}{2x}} = 2<br />
