Find Solutions to Tan x = Cos x in Radians
In summary, the conversation is about solving the equation tan x = cos x, with the answers expressed in radians and rounded to 4 decimal places. The conversation provides hints for solving the equation using the quadratic formula and the sine of the difference between two angles formula. The final answer is found to be 2.48 radians.
Mark53
93
Find all numbers x ∈ [0, 2π] satisfying tan x = cos x. Your answers should be expressed in radians, rounded to 4 decimal places. Show all your working.
[You will need to use a scientific calculator that has buttons such as sin−1 or arcsin so as to be able to find the angles for which the sin function attains given values.
[/B]
I don't know where to start I have had a look at the unit circle but can't see anywhere where they are equal
The hint they gives you suggests that you should be solving your equation for sin x. What is tan x in terms of sin x and cos x? If you substitute for tan x in your equation, what do you get?
Suggestion: Express ## \tan{x}=\sin{x}/\cos{x} ##. Also ## \ ## ## \cos^2{x}=1-\sin^2{x} ##. Much simpler to work with the ## sin{x} ## than to graph ## y= \tan{x} ## and ## y= \cos{x} ##. A graphical solution might be a good check for the solution.
tan x = sinx/cosx
which means
sinx/cosx=cosx
sinx=cos^2x
Is this what you mean?
Mark53 said:
tan x = sinx/cosx
which means
sinx/cosx=cosx
sinx=cos^2x
Yes. Now, what is cos^2 x in terms of sin^2x?
that means
sinx=1-sin^2x
Mark53 said:
that means
sinx=1-sin^2x
Good. Now solve this quadratic equation for sin x using the quadratic formula.
Mark53 said:
tan x = sinx/cosx
which means
sinx/cosx=cosx
sinx=cos^2x
It's clearer to write cos^2(x). Even better to use the Superscript feature, X2, to give cos2 x.
does that mean
sin x = (-1 +sqrt5)/2 or (1 +sqrt5)/2
Mark53 said:
does that mean
One of these roots is >1. As a decimal, what is the other root. What angles does your calculator say that this corresponds to on the interval between x = 0 and x = 2pi?
0.618 which means arcsin 0.618 = 0.6662
is this my answer?
is this my answer?
If I may offer a hint here=.666 radians is about 40 degrees. Is that the only place where sin(x)=.618?
is this my answer?
Not good enough. There is another angle on the interval that has this same value of sine.
it would be in the second quadrant but how do i calculate it
Using the sine of the difference between two angles formula, what is ##\sin(\pi -\theta)##?
does this mean that the other answer would be 3.8078?
No. It looks like you added your first answer to ##\pi##, rather than subtracting it from ##\pi##.
so the answer would be 2.48 radians
You can check both your answers by substituting them in your equation: ##\tan(x) = \cos(x)##. The left and right sides should be equal for those two numbers. Your calculator should be in radian mode, though.
Likes Mark53
Since you have rounded your answers (or at least haven't written all the digits shown on your calculator), the left and right sides of the equation will only be close, not exactly the same.
Likes Mark53
Thanks for the help
What is the meaning of "Find Solutions to Tan x = Cos x in Radians"?
This phrase refers to finding the values for x in radians that satisfy the equation Tan x = Cos x. In other words, we need to find the values of x that make the tangent of x equal to the cosine of x.
Why is it important to solve this equation in radians?
Radians are the standard unit for measuring angles in mathematics. This unit is preferred because it simplifies many trigonometric equations, making them easier to solve. It also allows for a more accurate representation of angles compared to other units such as degrees.
How do we solve the equation Tan x = Cos x?
To solve this equation, we need to use trigonometric identities and properties. First, we can rewrite the equation as Tan x - Cos x = 0. Then, by using the identity Tan x = Sin x / Cos x, we can substitute and get (Sin x / Cos x) - Cos x = 0. From here, we can simplify and solve for x using algebraic methods.
Are there multiple solutions to this equation?
Yes, there are infinitely many solutions to the equation Tan x = Cos x. This is because the tangent and cosine functions have a periodic nature, meaning they repeat their values after a certain interval. In this case, the interval is 2π radians, so there are infinite values of x that satisfy the equation.
How can we verify our solutions?
One way to verify our solutions is by plugging them back into the original equation and checking if they make the equation true. Another way is to graph the functions Tan x and Cos x and see where they intersect, which should coincide with our solutions.
