What Does 'pi/2 <t <pi' Mean in Trig Verbiage?
  • Thread starter Thread starter majinkenji
    Trig
The discussion focuses on interpreting the trigonometric expression "pi/2 < t < pi," which indicates that the angle t is located in the second quadrant of the unit circle. Participants suggest visualizing the expression graphically to better understand its implications. The second quadrant is confirmed as the correct interpretation, where cosine values are negative. This understanding helps clarify the position of the angle in relation to the coordinate plane. Overall, the conversation emphasizes the importance of quadrant identification in trigonometric contexts.
majinkenji
Hello,
In a trig verbiage such as "if cos t = -8/17 and pi/2 <t <pi" could someone please provide an alternate way of interpreting "and pi/2 <1 <pi"? I don't understand what is trying to be said with this portion. Any alternate interpretations would be wonderful.
Thank you for your support.
Best Wish,
mk
try drawing the expression \frac{\pi}{2} &lt; t graphically and reevaluating the problem.
Hello Pythagorean,
Is it basically just identifying its position on a coordinate plane? i.e. Q2 in this case?
Regards,
mk
majinkenji said:
Hello Pythagorean,
Regards,
mk
Yes, it means that the angle t is in the second quadrant.
ehild
I would say confining the solution to Q2, but yes.
Got it, thank you very much.
Regards,
mk
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
