Trigonometric equations - Find the general solution
The discussion revolves around solving the trigonometric equation cos x - √3 sin x = cos(3x). An initial attempt involved manipulating the equation but led to incorrect solutions. A more effective method was suggested, rewriting the equation as cos(3x) - cos x + √3 sin x = 0 and applying the identity for cos(3x). The correct general solutions were identified as nπ and π(3k + (-1)^k)/6, with participants confirming that the approaches yield equivalent results. The conversation highlights the importance of using trigonometric identities for accurate solutions.
Saitama
\cos x-\sqrt{3}\sin x=\cos(3x)
Dividing both the sides by two i.e
\cos x \cos \frac{\pi}{3}-\sin x \sin \frac{\pi}{3}=\cos (3x)/2
LHS can be written as ##\cos(x+\pi/3)##. Substituting ##x+\pi/3=t \Rightarrow 3x=3t-\pi \Rightarrow \cos(3x)=-\cos(3t)##
\cos t=-\cos(3t)/2 \Rightarrow 2\cos t+\cos(3t)=0
##\because \cos(3t)=4\cos^3t-3\cos t##
4\cos^3t-\cos t=0 \Rightarrow \cos t(4\cos^2t-1)=0
Hence, ##\cos t=0 \Rightarrow t=(2n+1)\pi/2 \Rightarrow x=(2n+1)\pi/2-\pi/3## and ##\cos t=±1/2 \Rightarrow t=k\pi ± \pi/3 \Rightarrow x=k\pi, k\pi-2\pi/3## where ##n,k \in Z##.
But these are wrong. The correct answers are: ##n\pi, \pi(3k+(-1)^k)/6##.
Any help is appreciated. Thanks!
It is too complicated. Try to expand cos(3x)=cos(x+2x) in the original equation.
ehild
ehild
I already devised a way to reach the correct answer. What I have posted above is my first attempt at the problem and I am curious as to where I went wrong with that.
To reach the correct answer, I would rewrite the given equation as ##\cos(3x)-\cos x+\sqrt{3}\sin x=0##. Rewriting ##\cos(3x)-\cos x## as ##-2\sin(2x)\sin x##, I can easily reach the correct answer.
##\because \color{red}{\cos(3t)=4\cos^3t-3\cos t}##
Where did that equation I have highlighted in red come from?
[Edit - added] Never mind about the identity. I think your work is correct and your answer and the "correct" answer are identical.
Pranav, I followed exactly your method and got the right answer. Your mistake must be after the word "hence". I got (using degrees) x = 180k + (0,30,60).
Yes, both answers reduce to ##n\pi, n\pi+\pi/6, n\pi+\pi/3##
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
