- 6,059
- 3,174
Going back to post 56, I now tried, just for the fun of it, to see if I could get another solution using @daverusin 's method of post 41. I tried ## m=7/3 ##, and I very readily got ## a=11 ##, ## b=131 ##, and ## x=79 ##.
I tested the solution to see if we have that ## x^2=(a^2+ab+b^2)/3 ## and we do indeed. :)
and one more I got easily is with ## m=8/3 ## that gives ## a=2 ##, ## b=167 ##, and ## x=97 ##.
and ## m=9/4 ## gives ##a=23 ##, ## b=218 ##, and ## x=133 ##.
and ## m=6/5 ## gives ## a=74 ##, ## b=107 ##, and ## x=91 ##. The method clearly works.
See also posts 46 and 47 for some further detail of the method.
It should be noted that for any rational coordinates on the ellipse, the slope ## m ## of the line connecting those coordinates with the point ## (-1,-1) ## will also be rational. Once again, when the expression for ## y ## from the equation of the line is put into the ellipse expression, and we solve the quadratic for ## x ##, we get two solutions, both rational with one of the solutions being ## x=-1 ##.
It might be worth mentioning that the method @renormalize used in post 32 was to try every possible integer solution and see if they satisfy ## x^2=(a^2+ab+b^2)/3 ##. With @daverusin 's method, we simply use all rational ## m's ## in the range where the line intersects positive ##x ## and ##y ## on the ellipse, and we find that every ##m ## we try works.
For ## m=7/5 ## we get ## a=71 ##, ## b=143 ##, and ## x=109 ##.
