Trigonometry problem of interest
  • Level: Undergrad
  • Thread starter Charles Link
81 replies · 18K views · last reply
Going back to post 56, I now tried, just for the fun of it, to see if I could get another solution using @daverusin 's method of post 41. I tried ## m=7/3 ##, and I very readily got ## a=11 ##, ## b=131 ##, and ## x=79 ##.
I tested the solution to see if we have that ## x^2=(a^2+ab+b^2)/3 ## and we do indeed. :)
and one more I got easily is with ## m=8/3 ## that gives ## a=2 ##, ## b=167 ##, and ## x=97 ##.
and ## m=9/4 ## gives ##a=23 ##, ## b=218 ##, and ## x=133 ##.
and ## m=6/5 ## gives ## a=74 ##, ## b=107 ##, and ## x=91 ##. The method clearly works.
See also posts 46 and 47 for some further detail of the method.
It should be noted that for any rational coordinates on the ellipse, the slope ## m ## of the line connecting those coordinates with the point ## (-1,-1) ## will also be rational. Once again, when the expression for ## y ## from the equation of the line is put into the ellipse expression, and we solve the quadratic for ## x ##, we get two solutions, both rational with one of the solutions being ## x=-1 ##.
It might be worth mentioning that the method @renormalize used in post 32 was to try every possible integer solution and see if they satisfy ## x^2=(a^2+ab+b^2)/3 ##. With @daverusin 's method, we simply use all rational ## m's ## in the range where the line intersects positive ##x ## and ##y ## on the ellipse, and we find that every ##m ## we try works.
For ## m=7/5 ## we get ## a=71 ##, ## b=143 ##, and ## x=109 ##.
additional numbers to complete the set with 5 in the denominator for ## m ##:
## m=9/5 ##, ## a=59 ##, ## b=227 ##, ## x=151 ##
## m=11/5 ##, ## a=39 ##, ## b=327 ##, ## x=201 ##
## m=12/5 ##, ## a=26 ##, ## b=383 ##, ## x=229 ##
## m=13/5 ##, ## a=11 ##, ## b=443 ##, ## x=259 ##
Notice as is mentioned in post 41 that ## x<0 ## for ## m> 1 +\sqrt{3} ##, (ellipse crosses y-axis at ## (0,\sqrt{3}) ## ), so that we don't need to go any higher with the numerator when the denominator is 5.
and I'll say it again as I said in post 56, that @daverusin has a post of considerable merit in post 41 . I still am the only one to give it a "like". Perhaps others have not looked it over carefully enough to figure out what he did, which I explained in posts 46 and 47 after I figured it out.
I might add that back around posts 22, 24, and 25 I was finding it very difficult to find combinations that work. Now with the method of post 41, every single one that I try works.
Charles Link said:
You might also include that when you used the cosine theorem that both are equal to ## c^2 ##.
Okay.
## c^2=a^2+(2R)^2-2\cdot a\cdot2R\cdot\cos(\angle ADC) ##
## c^2=x^2+b^2-2\cdot x\cdot b\cdot\cos(\angle ABC) ##
I want to offer one more solution to show that the decision between ## c ## or ## d ## is irrelevant.
## \cos(\angle BCD)=b/(2R) ## from The definition of cosine in the context of a right-angled triangle
## \angle BCD+\angle BAD=180^\circ ## from The inscribed angle theorem
(## d^2=b^2+(2R)^2-2\cdot b\cdot2R\cdot\cos(\angle BCD) ## and
## d^2=x^2+a^2-2\cdot x\cdot a\cdot\cos(\angle BAD) ##) ## \implies ##
## \implies b^2+(2R)^2-2\cdot b\cdot2R\cdot\cos(\angle BCD)=x^2+a^2-2\cdot x\cdot a\cdot\cos(\angle BAD) ## from The cosine theorem
Above three equations imply
## \cos(\angle BCD)=(b^2-x^2-a^2+(2R)^2)/(2\cdot(b\cdot2R+x\cdot a))=b/(2R)\implies x=7 ##.
The same procedure, the same result.
Just last night, I put an Edit 2 to post 48 that some may find of interest. Finding positive rational solutions to the problem ##x^2+x+1=y^2 ## turns out to be rather easy for this rotated ( 90 degrees) and translated hyperbola, using the method of posts 41 and 46. The starting point is the solution ## (-1,1 ) ## and the other points of intersection of lines with slope ## m ## through this point are found, for all rational ## m ## with ## 0 < m < 1 ##. Using this method, the solutions are ## x=(m^2+2m)/(1-m^2) ## and ## y=(m^2+m+1)/(1-m^2) ##.
For ## m=1/2 ## we get ## x=5/3 ## with ## y=7/3 ##. It is a simple matter to find many solutions.
I'm finding it somewhat amazing how the ai overview is able to summarize for me the steps that are needed for the method of finding rational roots of a conic section with linear parametrization using the rational root theorem. I would like to copy and paste their summary which I think even did a better job of it than I did in post 46, that I also used in posts 56 and 64 above. That is presently against PF rules though and I am ok with that. We really don't need modern technology replacing our skills more than it already has. With all its apparent looking smart on the surface, I don't think this ai stuff is capable of intelligent thought.
By replacing humans with artificial intelligence, this forum would lose its soul, and some kind of emptiness would be left.
@Gavran Still I am a little disappointed that the PF members who can respond to these posts don't seem to have looked carefully over post 41 by @daverusin to get the same kind of adventure from it that I got. I tried to summarize what he did once I figured out his method. He didn't present a great deal of detail, so it took me a day or so to figure out the method which was new to me. I tried to summarize what he did in posts 46 and 47 and 56, but I have to wonder if the ai summary I read was perhaps one better than what I presented.
In any case, I am pleased with the course this thread took. When I started it, I certainly wondered with the arithmetically complex solution I had, how they ever got an integer solution of ## x=7 ##. Was it pure luck, and almost one of a kind, or was there some simple underlying explanation?, which there was, as we found as the thread progressed.
Edit: and it was icing on the cake when I found I was able to use the method of post 41 on the form ## x^2+x+1 =y^2 ## that I also mentioned in post 48.
CAD drawing of a regular hexagon in blue inscribed in a magenta circle, with an R2.00 blue circle at its left vertex, an R11.00 arc, labelled sides 7.00, a red chord, a green side, and cos θ = 1/x, with θ and 180 - θ marked.
  • Geometric construction diagram with a regular hexagon in magenta and a blue pentagon-like polygon inside a large circle, labelled R11.00, R2.00, R7.00, 11.00, 2.00, 7.00, 7.00 and x = 7.00, with angle theta and 180 - theta marked and the note cos theta = 1/x in red.
Thanks - just once though! Since one triangle is right, Pythagoras will there suffice.
@neilparker62 My solution with your diagram is simple.
Let RL=red line.
Then ## (RL)^2=2^2+4x^2-2(2)(2x) \cos{\theta} ##
and ## (RL)^2=11^2+x^2-2(11) x \cos(180-\theta)=11^2+x^2+2(11)x \cos{\theta} ##
(both are law of cosines)
with ## \cos{\theta}=2/(2x)=1/x ##
We set the two ## (RL)^2 ## equal to get ## x^2=(2^2 +(2)(11)+11^2)/3=49 ## so that ## x=7 ##.
Let RL=red line.
or ##RL^2 = (2x)^2 - (2)^2 = 4x^2-4##
We can also draw the other diagonal and apply Ptolemy directly:
##2x + 22x = \sqrt{4x^2-4}\times\sqrt{3x^2}=2x\sqrt{3x^2-3}## etc
I think the simplest way to get the result is by using the triangle with sides 2, 11, and AB in the modified figure below. The length of segment AB is twice the height of an equilateral triangle of side x, and the angle between the side of length 2 and that of length 11 is ##2 \pi/3##. From the cosine theorem, we get the value x=7.
CAD drawing of a regular pentagon with vertices A and B, a magenta circumscribed circle labelled R7.00, and dimensions 7.00 for sides, R2.00 and R11.00 arcs, and a green segment labelled x = 7.00 from B.
Definitely the most efficient solution!
I thought @hutchphd 's of post 49, (see also post 52) was simpler. I think this latest (post 73) I would call "a" most efficient solution, but not "the" most efficient. :)
Edit: Notice it does indeed give the general result that ## x^2=(a^2+ab+b^2)/3 ##.
Charles Link said:
@hutchphd a super result. :) With a couple algebraic steps one gets ## 3x^2=11^2+2^2+(2)(11) ##. I'll let you write it out, but if you don't get to it in a day or so, I could post the 3 equations and their rather straightforward solution.
Perhaps worth noting (in retrospect) that you will get this equation directly by implementation of @GiorgioPastore 's suggestion in post #73.
Very interesting discussion on parameterization of this problem. Am still trying to get my head round some of those posts! See also https://en.wikipedia.org/wiki/Diophantus_II.VIII. The technique seems similar.
Edit: Paramaterization solution as per post #46 and solution with m=2.
@neilparker62 This parameterization method is really kind of simple once you figure it out, and it's based on solutions using the quadratic formula, that for both the plus and minus solutions, the square root of ## b^2-4ac ## will be rational, making for two rational solutions, one of which is the point that was selected as the starting point.
For the case at hand ## x^2+xy +y^2-3=0 ## is a rotated ellipse, and ## (-1,-1) ## makes for a very good point to use as one solution on the ellipse. With any line of slope ## m ## that passes through this point, there will be another rational solution ## (x,y) ## on this ellipse.
Yes - as mentioned above the technique is strikingly similar to that employed in Diophantus II VIII which is "to divide a square into two other squares" - I take the liberty of copy/pasting the image from Wikipedia which illustrates the technique when the given square is 16. y=mx-4 is constructed and intersects the circle at the rational point (0;-4). The other point of intersection is also rational and is shown in the diagram with m=2. You might find it interesting to "parameterize" this solution.
As the old saying goes "there is nothing new under the sun" !
Coordinate diagram of circle y^2 = 16 - x^2 centred at origin O, with axes x and y. Labels (0;4) and (4;0) mark the top and right intercepts. Point B at (16/5, 12/5) is joined to O and to C, where line y=2x-4 meets the circle at the bottom. Point A is directly below B on the x-axis.
TensorTronic-270 said:
Might help?
Sometimes it's simpler to use degrees rather than radians for the measurement of angles.
Some of it depends upon who the audience is. If you have a construction worker building something, he'll know immediately what a 90 degree angle is, but if you tell him you want it to be ## \pi /2 ## radians, good luck. LOL
