Trigonometry triangle Question
The discussion revolves around understanding trigonometric functions in relation to a triangle with angles of 90°, 60°, and 30°. It clarifies that for sin 90°, both the opposite and hypotenuse are equal to r, leading to sin 90° being 1. The conversation also addresses how cos 90° equals 0, as the adjacent side x approaches zero when the angle approaches 90°. Participants emphasize the importance of visualizing the triangle and the relationships between the sides as angles change. The use of a unit circle is suggested for a clearer understanding of sine and cosine values across different angles.
basty
For the triangle shown in the below image,
##\sin 60° = \frac{opposite}{hypotenuse} = \frac{y}{r}##
##\sin 30° = \frac{opposite}{hypotenuse} = \frac{x}{r}##
The questions are:
1. What is the opposite and hypotenuse of sin 90°?
2. I am guessing that the opposite and hypotenuse of sin 90 is
r and y respectively so that ##\sin 90° = \frac{opposite}{hypotenuse} = \frac{r}{y}##.
Why sin 90° = 1?
Mathematics news on Phys.org
If you use the opposite over the hypotenuse definition then you'd get sin(90) = r/r = 1
Do you mean that the sin 90° is: the opposite = r and the hypotenuse is = r too?
How do you obtain ##\cos 90° = \frac{adjacent}{hypotenuse} = \frac{x}{r} = 0##?
Look at your triangle. As the angle θ gets larger, the length of the base x gets smaller. The radius r remains constant. When θ = 90°, what must x be?
There is no θ in my triangle. There are 90°, 60°, and 30° angles. Which one you meant as the θ?
The angle which is labeled 60° in your diagram.
The trig functions are defined as in this diagram:
Which side you meant by the radius?
The θ you meant is the one labeled as 60°, but the cos 90° I meant is the right angle.
What should the cos 90° be if the angle is the right angle, not the 60°?
In your diagram of the triangle, the side labeled "r", which I indicated as "the radius r".
Yes, but in order to calculate sine and cosine for 90°, you pretend to let the angle labeled 60° in your diagram increase to 90°, and examine what happens to the sides x and y in order for this to happen.
cos (90°) = 0, always.
Instead of using just a triangle to define the trig functions, often a unit circle (radius = 1) is used, like this:
As the point P moves counterclockwise around the circle, the coordinates x and y of P are also the values of cos (θ) and sin (θ), respectively.
Here is another diagram showing how sin (θ) varies for different angles θ drawn on a unit circle:
