Trigonometry Word problem with angles of elevation
11 replies · 7K views · last reply
jmgXD6
An Antenna that is 90 feet high is on top of a hill. From a point at the base of the hill, the angles of elevation to the top and bottom of the antenna are 28.5° and 25°, respectively. To the nearest whole number of feet, how high is the hill?
A, 189 ft
B, 213 ft
C, 548 ft
D, 623 ft
E, 697 ft
well I know Sinθ=o/h Cosθ=a/h Tanθ=o/a
I don't know the length of the base so I couldn't figure it out like the textbook examples, but from angle 25° I figured the hypotenuse to the base of the antenna was 212.5, which would round to 213 so I know A and B can't be it.
A, 189 ft
B, 213 ft
C, 548 ft
D, 623 ft
E, 697 ft
I hope you have a drawing of the two triangles that represent this situation. You have the hypotenuse of the right triangle whose acute angle is 25°. That makes the other angle of this triangle 65°. You are given the length of the side opposite the 3.5° angle, and you should be able to figure out the obtuse angle of the upper triangle. Knowing two angles and a side, you should be able to use the Law of Sines to determine the hypotenuse of the upper triangle, and then get calculate the height of the hill.
Where did you get 3.5° and where would the 28.5° angle go?
Call the height of the hill ##h## and the distance from the base of the hill ##d##. Write the equations for the tangents of your two angles. Two equations in unknowns ##h## and ##d##. Eliminate the ##d## and solve.
28.5° - 25° = 3.5°
There are three triangles involved: the lower triangle (a right triangle with an acute angle of 25°); the upper triangle that has one angle of 3.5°; a large right triangle that contains the two previous triangles, and that has an acute angle of 28.5°.
You have made a drawing, right?
I like your strategy better than mine...
jmgXD6 said:
I know where to put the lower triangle, but where would the top angle of evaluation, 28.5 degrees, go?
Here's what I drew so far.
http://s288.photobucket.com/user/AC...lusquestion85_zpse8fde88e.jpg.html?sort=3&o=0
That's angle of elevation, not evaluation. You had that in your title, and I fixed it.
Your picture is wrong. You have the angle of elevation to the top of the antenna as 25°. It should be 28.5°. The angle of elevation to the bottom of the antenna is 25°.
So where I had 25 degrees it should be 28.5, and 65 should be 61.5 degrees, correct?
jmgXD6 said:
So where would the bottom angle of elevation go then?
Read your original post. It tells you.
