Triple integral and charge density
The discussion focuses on calculating the total electric charge in a layer of ions bounded by the planes defined by the equations x + 2y + 2z = 4 and x + 3y + 3z = 3, along with the three coordinate planes. The charge density increases linearly from zero at the outer plane to 10^15 at the inner plane. To compute the total electric charge, participants suggest using a triple integral of the charge density function, which can be simplified if the planes are parallel. The correct approach involves integrating the charge density function over the specified volume.
  • Understanding of triple integrals in calculus
  • Knowledge of electric charge density concepts
  • Familiarity with the equations of planes in three-dimensional space
  • Basic principles of integration in physics
  • Study how to derive charge density functions from boundary conditions
  • Learn about calculating triple integrals in three-dimensional coordinate systems
  • Explore the relationship between surface charge density and volume charge density
  • Investigate the implications of parallel planes on electric field calculations
Students and professionals in physics, particularly those focusing on electromagnetism, as well as mathematicians dealing with calculus and integrals in three dimensions.
Dan7620
Alright guys I am looking for some help with this problem regarding calculating total electric charge in a layer of ions. This layer of ions is bounded between the planes x+2y+2z=4 and x+3y+3z=3, and by the 3 co-ordinate planes. The density of the ions is rises linearly from zero at the outer plane ( x+2y+2z=4) and increases linearly to 10^15 at the inner plane (x+3y+3z=4). Furthermore, the surface charge density is constant in planes parallel to the planes x+2y+2z=4 and x+3y+3z=4.
I see that in order to calculate the total electric charge I must compute a triple integral of the charge density, however I'm trying to find an expression for the charge density function. Could anybody help me with writing density (as a function of x,y,z) based upon the information given in the first paragraph? Not looking for the final answer here, just some instruction. Thank you :)
PS. I wasn't sure whether this should be posted here or in the electrical section, sorry just in case.
EDIT: the second plane, x+3y+3z=3 is incorrect, as it is not parallel to the first one, x+2y+2z=4 (it should be).
As you have said, the two planes aren't parallel, and the boundaries of the required volume isn't specified. If the two planes are suppposed to be parallel, you don't have to resort to fancy triple integration to find total charge. Just find the perpendicular distance between the 2 plane, and then you can easily do an integration in one variable to find the charge stored in a volume element Adx, where dx is an incremental thickness.
Should have rewritten it as the integral: \int^{x_2}_{x_1} \lambda (x) A dx where \lambda is the total charge per infinitesimal sheet between the 2 planes.
Ah ok, thanks a lot, much simpler.
