Triple Integration: Solve Homework Equation
Quatros
I'm trying to figure out the other parameters to solve the problem
I know sqrt(x^2+y^2+z^2) = p
I changed the integrand to p^3 sin(theta) since p * p^2 sin(theta)
Then for the first integration sign, I know how to get the rest of them.
The differential volume ## dV=r^2 \, \sin{ \theta} \, dr \, d \theta \, d \phi ## in spherical coordinates. You need to integrate the function over this and pick the limits on ## r ##, ## \theta ##, and ## \phi ## correctly.
but isn't that cylinderical cordinates.
No. Cylindrical coordinates is like polar coordinates in two dimensions and also has a ## dz ##.
Charles Link said:
The problem asks for spherical coordinates. Read it carefully.
It's p for sphere our in our book, unless you aren't talking about integrand.
You can call it ## p ## or ## \rho ## or ## r ##, just so that you are consistent.
Alright, I changed
Sqrt[x^2+y^2+z^2] to p * p^2 * sin(theta)
Would the z= sqrt(4-x^2+y^2) turn into sqrt(4-p^2)?
Where is the ## dp ##, ## d \theta ## , and ## d \phi ##? Also, what do the limits need to be on ## p ##, ## \theta ##, and ## \phi ##? If you know how spherical coordinates work, the answer is simple. Incidentally, I think the book is using the Greek letter "rho"=##\rho ##, but it's easier to use ## r ##.
P 0 to sqrt(4-p^2)
Theta from 0 to 2pi?
the other symbol from 2 to 2?
The boundary of the surface you should recognize as a hemisphere of radius ##r=2 ##. It is very easy to write the limits for it in spherical coordinates=Suggestion is you google "spherical coordinates" and study the explanation.
yeah, I did that and still confused. Sorry about my bad english.
## \phi ## is the azimuth angle. It is the same angle as the ## \phi ## in cylindrical coordinates. The ## \theta ## is the tricky one in polar coordinates. It is measured from the z-axis. In the entire sphere, ## \theta ## goes from 0 to ## \pi ##. For a hemisphere, it goes from ## 0 ## to ## \pi/2 ##. Polar coordinates is much easier explained holding a pencil and showing where it points. It's much easier to describe in person than in a write-up on the internet. But anyway, if you start with the pencil pointing upward, along the z-axis, that is ## \theta =0 ##. Tilt the pencil down slightly, and you tilt it down by angle ## \theta ##. Depending on the direction you tilt it, that defines the ## \phi ## angle...Rotate the tilted pencil (and yourself) around the z-axis (i.e. turn to the left or right), and ## \theta ## stays constant, but you change ## \phi ##.
Is this graph an Ice cream com
This is an ice cream cone, so the ball part (theta) is going from 0 to 2pi , P/R: 0 to 2,
The third parameter is giving me trouble.
Quatros said:
Is this graph an Ice cream comThis is an ice cream cone, so the ball part (theta) is going from 0 to 2pi , P/R: 0 to 2,
(Referring to the hemisphere that is the boundary), ## \phi ## goes from ## 0 ## to ## 2 \pi ## (## 360^o ##). The polar angle ## \theta ##, goes from ## 0 ## to ## \pi/2 ## (## 90^o ##). It's probably not obvious if this is the first time you used spherical coordinates, but with a little practice, it gets easier.
Is 8 pi correct?
Likes Charles Link
Quatros said:
Is 8 pi correct?
Yes, that's what I get also.
