Trouble with BLAS subroutine dgemv ->vector- matrix product
The discussion revolves around troubleshooting issues with the BLAS subroutine dgemv for computing the vector-matrix product. The user, miss fangula, initially encounters unexpected results when using the dgemv function in their code, which involves a matrix defined as "Array" and a vector called "vector." Key points include the realization that the sine and cosine functions expect radian inputs, not degrees, which was causing incorrect calculations. After correcting the input to radians, the output became accurate. Additionally, there is a query about the difference between matrix-vector and matrix-matrix products, leading to the clarification that while dgemv is used for vector-matrix products, a different subroutine, dgemm, is necessary for matrix-matrix products. The discussion highlights the importance of input formats and the appropriate use of BLAS subroutines in linear algebra computations.
missfangula
Trouble with BLAS subroutine dgemv -->vector- matrix product
Hello all,
So, I am trying to write some code that will compute the vector-matrix product using the BLAS subroutine dgemv. I have written the code below, but I am getting really wacky numbers! You will see that it takes array "Array" as the known matrix , and vector 'vector' as known vector, and outputs a product vector.
Does anyone know what maybe askew?
Thanks a million,
miss fangula
#import <Foundation/Foundation.h>
#include <Accelerate/Accelerate.h>
#include <stdlib.h>
#include <stdio.h>
//#include <math.h>
//*******FINDS X IN MATRIX EQUATION AB = X, WHERE A AND B ARE KNOWN MATRICES*******//
// [a a a] [b b b] [x x x]
// [a a a]*[b b b] = [x x x] {x,x,x,x,x,x,x,x,x} = ?
void printMatrix(char* name, int n, double* b, int lda);
/*Define all subroutine parameters*************************/
#define M 4 //Define 'Array' matrix size and number of rows in 'vector'
#define N 4 //Define number of columns in 'Array' (if a vector, then probably 1)
#define ALPHA 4 //Scaling constant alpha
#define LDA 4 //Leading dimension of 'Array'
#define INCX 1 //Stride value for 'vector' and can have any value
#define BETA 0 //Scaling constant beta
#define INCY 1 //Stride for 'y'
int main()
double *vector;
double *y;
int m = M;//Define local variable n to be N
int n = N;//
int alpha = ALPHA;
int lda = LDA; //Define local variable lda to be LDA
int incx = INCX;
int beta = BETA;
int incy = INCY;
double a = 0.0;
double b = 180.0;
double R = 1.54;
double Array[16] = //Declare a NxN array 'Array'
-cos(a), sin(a)*cos(b), sin(a)*sin(b), 0.0,
-sin(a), -cos(a)*cos(b), -cos(a)*sin(b), 0.0,
0.0, -sin(b), cos(b), 0.0,
-R*cos(a), R*sin(a)*cos(b), R*sin(a)*sin(b), 1.0
vector = calloc(4, sizeof (double)); //Declare a vector to as other unknown in equation (see algorithm above)
y = calloc(4, sizeof (double));
*vector = 0.0; //Define first element of vector b
*(vector + 1) = 0.0; //Define second element of vector b
*(vector + 2) = 0.0;
*(vector + 3) = 1.0;
cblas_dgemv(CblasRowMajor, CblasNoTrans, m, n, alpha, Array, lda,
vector, incx, beta, y, incy);
/*cblas_dgemv(CblasRowMajor, CblasNoTrans, 3, 3, 1.0, m, 3,
x, 1, 0.0, y, 1);*/
printMatrix("Answer is: ", n, y, lda); //Print the solution matrix 'x'
free(vector); //free the input vector
free(y); //Free the solution vector
return 666; //since int main function, return some integer
void printMatrix (char* name, int n, double* b, int lda) //Function to print the solution matrix
int loopNumber;
int numTimes = n;
printf("\n %s\n", name); //Print name of solution matrix 'x'
for (loopNumber = 0; loopNumber < numTimes; loopNumber++) //For each element of vector
printf("%6.2f", b[loopNumber]); //Print the respective element at loopNumber position
printf( "\n" ); //Space
Technology news on Phys.org
i should add that i am running this on a mac. so i am using the accelerate framework for lapack (and blas, too, I believe)
Check your use of sin(b) and cos(b). Those functions are expecting radian arguments.
Also,
What numbers were you expecting? What numbers are you getting?
Be aware, the routine "dgemv" returns a matrix-vector operation
y := alpha*A*x + beta*y,
or
y := alpha*A'*x + beta*y,
depending on the value of "CblasNoTrans". Here, "alpha" and "beta" are scalar.
I suggest you try a simple test case with some know variables.
Hi,
I set beta scalar to be 0.0, and alpha scalar to be 1.0, so now it should output the product of a matrix A and a vector x, correct? A*x = ?
I tested the program with various 2x2, 3x3, and 4x4 matrices, all with constants as elements in the array. I got the correct answers.
Then I tried it as posted in this forum, with variables for elements in the array. I get wrong answers. I checked the results with an online matrix multiplication calculator (joemath.com)
I think I have narrowed down the problem to either one of two things:
1. I cannot use variables for the array elements
2. sine is in radians, and I am putting in degrees
I will now try out the radian version, and see what happens. Otherwise, does anyone know of a rule that you cannot use variables as array elements in c? I thought that was only when allocating the size of the array (need a constant for array size)...
-miss fangula
It shouldn't be a problem using variables to intitialize the array, but it's definitely a problem that you are using degrees instead of radians.
hi,
I just tried it with radians, and it works. mystery solved.
Hi
I had another question, kind of silly maybe. What is the difference between a matrix-vector product and a matrix-matrix product in programming? Aren't they are just a bunch of arrays? If s0, then can I use the dgemv subroutine to multiply two 4x4 matrices, do I have to use another subroutine, like dgemms?
Thanks!
-miss fangula
