Understanding the Troublesome Equation: Tips for Solving Math Problems
  • Thread starter Thread starter Kurdt
Kurdt
Staff Emeritus
Just looking for some advice on where my maths is going wrong with this. I have the following equation.
L_{orb}=(\frac{GD}{M})^\frac{1}{2}M_sM_p
and information that the time derivatives of L and M are zero. Also M_s varies with time along with D. I am supposed to arrive at the following equation.
\frac{\dot{D}}{D}=-2(1-\frac{M_s}{M_p})\frac{\dot{M_s}}{M_s}
I first brought the M over to be on the same side as the L as when I take the time derivative they will be 0 and then after taking the time derivative of what is left on the left hand side and rearranging a little I can only get
\frac{\dot{D}}{D}=-2\frac{\dot{M_s}}{M_s^2}
Any pointers as to where my maths fails. I realize it could have something to do with a substitution of variables but I'm assuming not as it seems unlikely at the minute and I wouldn't like to type out all the possibilities :wink: . Any help is much appreciated.
What's r and b?
(This looks like some sort of spin equation in a gravitational field, but..)
And M? Do you mean M_{p}?
sorry r and b was supposed to be part of the subscript I will change it and M is the sum of M_p and M _p.
Its just basically the orbital angular momentum in the Roche model of binary stars which I am studying at the minute. Trying to extract useful information on the rate of orbital decay.
Remove the G^{\frac{1}{2}} over as well.
Then we have:
0=\frac{\dot{D}}{2\sqrt{D}}M_{s}M_{p}+\sqrt{D}\frac{d}{dt}(M_{s}M_{p})\rightarrow\frac{\dot{D}}{D}=-2\frac{\frac{d}{dt}(M_{s}M_{p})}{M_{s}M_{p}}
The desired expression is now readily obtained
Thanks for your help. I knew it was something simple that I'd missed.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
