Trying desparately to wrap my head around proportional relationships
The discussion centers on understanding the mathematical formalization of proportional relationships among three quantities, x, y, and z, under various conditions of increase and decrease. It explores how changes in x affect y and z, with specific factors such as F, 2F, and √F. The participants analyze the implications of these relationships, questioning the meaning of "increase/decrease by a factor" and how it relates to proportionality constants. A key point raised is that the proportionality constant q varies depending on the factor F, complicating the relationships. Ultimately, the conversation highlights the need for clarity in defining these proportional relationships to avoid confusion.
Ontophile
A) Suppose that we have 3 quantities, x, y, and z. An increase in x by a factor of F is followed by a subsequent increase of y by a factor of 2F. Furthermore, the very same increase in x by a factor of F results in a subsequent decrease of z by a factor of F/2. Similarly, when x is decreased by a factor of F, y is decreased by a factor of F/2 and z is increased by a factor of 2F. How do I mathematically formalize this relationship between x, y, and z?
B) Now suppose that an increase in x by a factor of F yields an increase in y by a factor of F2 and a decrease in z by a factor of √F (I assume that that's a square root symbol). How do I mathematically formalize THIS relationship between x, y, and z?
C) Lastly, suppose that an increase in x by a factor of F increases y by a factor of F and decreases z by a factor of F? How do I mathematically formalize THIS relationship between x, y, and z?
Note, if y were proportional to x, then increasing x by a factor of F would also increase y by a factor of Fq
if y = x2 then increasing x by F increases y by F2
If q=1 then y is directly proportional to x
If q < 0 they y is inversely proportional to x
The proportionality is characterized by q as in "inverse-square" for q=-2.
the described, increase by F leads to increase by 2F means
if we start at x=1, and put y(1)=a
then at x=2, x has doubled for F=2, so y must have quadrupled: 2F=4 to 4a
at x = 3, F=3, so 2F=6, so y(3)=6a;
continuing gives:
x = {1, 2, 3, 4, 5,...}
y = {a, 4a, 6a, 8a, 10a,...}
x(4) = 4x(1) means y(4)=8y(1): which is what we have above
x(4) = 2x(2) means y(4)=4y(2) means 4.4a=8a - which is false.
since 8a ≠ 16a, this interpretation of "increase by a factor" is flawed.
If it just means x→x+F => y -> y→2F, then this is satisfied by y=2x
But we are also told that x→x-F => y→y-F/2 (by the same interpretation).
This won't work for y=2x.
I can see how you got confused! What exactly does "increase/decrease by a factor" mean in this situation?
Can we find q so that Fq = 2F
well: this means F(q-1)=2
which means q-1 = log_F(2) = \frac{\ln(2)}{\ln(F)}
suggesting that the value of q depends on the value of F.
eg, if F=2 the q=2, if F=4, q=3/2
so the answer is "no" and we are back with:
We can see this when we realize we are looking for y=f(x) with the property that f(Fx)=2F.f(x)
When F = 1 (no change) this reduces to f(x)=2f(x) which is false.
ref:
http://www.phy.syr.edu/courses/PHY106/Slides/PPT/Lec2-Proportionality-Algebra.pdf
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
