Trying to determine the size of Diodes required
The discussion revolves around determining the appropriate size and type of diodes needed for a project involving the installation of a light bar and flood lamps on a Jeep. The focus is on ensuring proper functionality and isolation of the lights when controlled by relays, with considerations for current ratings and configurations.
  • One participant outlines a plan to use relays to control the LED light bar and flood lamps, expressing uncertainty about the size and direction of diodes needed for the circuit.
  • Another participant suggests specific diodes (6A10 and 10A10) based on their current and voltage ratings, emphasizing the need for diodes that can handle high temperatures and reverse current.
  • A later reply clarifies that the light bar operates at 10 amps, while each flood lamp operates at 1.5 amps, raising questions about the capacity of the suggested diodes.
  • One participant proposes using small signal diodes for relay coils instead of full load current, indicating a potential alternative approach to wiring.
  • Another participant emphasizes the importance of isolating the flood lamps from reverse voltage and suggests that diodes should be installed in specific locations on the circuit diagram.
  • Further discussion includes the idea of using one relay per light or set of lights to simplify the circuit and reduce the need for high-capacity diodes.
  • Participants discuss the necessary ratings for the diodes, suggesting that they should be rated above 1.5 A and around 20 V, and mention the possibility of sourcing components locally.
Participants express differing views on the best approach to wiring the diodes and relays, with some advocating for individual relays for each light and others suggesting a combined approach. There is no consensus on the optimal diode configuration or size, and the discussion remains unresolved.
Participants mention various assumptions about current ratings and configurations, but there are unresolved details regarding the specific wiring and diode placement in the circuit. The discussion also reflects uncertainty about the implications of using different diode ratings and types.
DakotaE
Hey All, i just joined today to try and figure out what size of diodes i need for the project I am working on.
I am working on installing a new Light Bar and Flood Lamps to my Jeep to get better light at night.
This is my hope to accomplish:
Relay 1 will be used to turn the LED Light Bar and Both Side Floods on when i activate the BRIGHTS in my headlights. The power for this relay will be controlled by RELAY 2, which will allow me to control whether or not the LEDS come on when the Brights are activated (I don't want LED's on when I am driving on Freeways in cities). Relay 2 will be controlled by a switch in the cab of my vehicle.
This is where it gets tricky...
I want to have functionality to be able to turn JUST the Right Flood ON or JUST the Left Flood ON when I am doing my security checks at night, without the LED Light Bar on at the same time. Relay 2 Controls just the Left Flood, Relay 2 Controls just t he Right Flood. Those will both also have swiches in the cab to control the on/off feature. I've circled where I am sure i need the Diodes to go, just unsure what direction to install them and what size i need to install.
Welcome @DakotaE to Physics Forums!
I would help you to choose such a diode which will work perfectly in those circled regions.
For High Current like a 6Amp supply of 12 Volt. You need to consider such a diode whose Reverse current is minimum and high operating temperature handling capabilities (Because at 6A, things would get hot enough). So Its better to choose such a diode which would work in all the conditions (specifically for your application).
I would suggest one of the following diodes to be connected:-
1) 6A10 (MIC)
Mounting Style: Through Hole
Package / Case: R-6
Vr - Reverse Voltage: 1 kV
If - Forward Current: 6 A
Type: Standard Recovery Rectifiers
Configuration: Single
Vf - Forward Voltage: 900 mV
Max Surge Current: 400 A
Ir - Reverse Current: 10 uA
Series: 6A10
Packaging: Reel
Height: 9.1 mm
Length: 9.1 mm
Maximum Operating Temperature: + 175 C
Minimum Operating Temperature: - 65 C
Operating Temperature Range: - 65 C to + 175 C
Termination Style: Through Hole
Width: 9.1 mm
Unit Weight: 0.074075 oz
2) 10A10 (MIC)
Part No: 10A10
Repetitive Peak Reverse Voltage(VRRM): 1000V
RMS Reverese Voltage: 700V
FWD Voltage(VF): 1V@10A
AVG Rectified Output Current: 10A @ 50C
Peak Reverse Current(IRM): 10uA @25C and 100uA @ 100C
Typical Junction Capacitance: 80pF
Typical Thermal Resistance Junction To Ambient: 10C/W
The above two listed diodes are best suited for your application.
Choose anyone of them, buy them at
"http://www.ebay.com/itm/10-Pack-6A10-Diodes-6-amp-1000-volt-Quick-and-free-shipping-from-USA-/132114125153"
or
"http://www.ebay.com/itm/20pcs-10A10...1fa9921&pid=100009&rk=1&rkt=1&sd=132114125153".
Connect them in a Positive biased configuration, this would make it possible to switch the lights at any desired time.
I just looked at my notes, and the lightbar is actually 10 amps (24 x 5 watt diodes) Is the 10A10 higher capacity then the 6A10? i don't know anything about Diodes. I am assuming the side with the little mark on it goes the battery side? what side of the diode would i hook to the LED Flood Lamp To?
Having a little trouble understanding what you want. A truth table would be nice. Chances are if you do your relays right all you need is a couple of small signal diodes that are able to handle relay coil current. Not full load current.
Averagesupernova, what I am trying to accomplish is isolating the flood lamps from backwards voltage so i can either run both floods and the lightbar at the same time using one switch, or i could use one of the floods without the other flood and the lightbar from illuminating using a separate switch. I need to install diodes where i have circles on the diagram. I need to know how big of a diode to install to keep the voltage going only one way from the Lightbar feed. I hope that clarifies what I am wanting to do.
The lightbar is 10 amps and each flood lamp is 1.5 amp
I wouldn't wire it that way. One relay per light or set of lights. Why be tying them together after the relay where you have to deal with full load current? Do the diode work on the wires that feed individual relay coils and deal with much lower currents.
OK - in your desired scheme: R1 + R2 = All lights on, R3 = Just the Left, and R4 = Just the right.
In the way you have it The Blocking diodes ONLY need to carry the current of the side lights when R1+R2 are on. ( individually 1.5 A)
Connect them like THIS - the banded end of the physical diode, is the "bar" end in the symbol. (The diode will NOT carry any current needed by the main light bar , so they do not need a > 10A rating)
So you want 2 diodes, rated > 1.5 A and > ~20 V.. THESE 100V. 6A diodes will work. Radio Shack does not have them on line, but I'll bet a few calls to the local stores you can fins one package.
As Averagesupernova pointed out you can you can also do this with the relays, and use a smaller diode, I probably still would not go below 1 A - Example - Clearly RadioShack can not count,,,,I will miss having SOME source of components immediately available.
  • · Replies 17 ·
