Trying to understand special relativity
The discussion focuses on understanding the basic concepts of special relativity, particularly regarding simultaneous events observed from different frames of reference. A moving observer O' at velocity v is considered, with two simultaneous events occurring at equal distances L from O'. The key recommendation is to use Lorentz transformations instead of relying solely on time and length dilation equations, as this approach simplifies the calculations. The participants confirm that using Lorentz transformations effectively clarifies the relationship between the events and the observers' perspectives. Overall, the conversation emphasizes the importance of mastering Lorentz transformations for tackling special relativity problems.
loobloke
I'm just trying to figure out the basic concepts of relativity and I just seem to confuse myself more the more I think about it.
Consider a moving observer O' at velocity v in one dimension.
Two simultaneous events, each distance L away from the observer occur.
What is the time difference between the 2 events as observed by O'?
How far will the moving observer O' be observed to have moved during this time difference by a stationary observer O.
Time Dilation
Length Dilation
Is there like a trick to approaching questions like this and to understand the basic concepts for this kind of stuff?
Cheers guys.
EDIT: Should have probably put this onto the introductory forums. Sorry!
The description is a little bit unclear. I presume that the two events in two opposite directions from O'.
In my opinion, the trick to approaching these questions is simply to use Lorentz transformations, rather than try to work from the dilation equations. It's easy to slip up in just apply dilation, whereas if you use the Lorentz transformations the dilation falls out immediately.
As I read your problem, you have a three events defined in a frame "O". Events are locations by a single space co-ordinate along a line, and a time at which it occurs. We'll put the observer O' at the origin at time 0, and have the events also at time 0.
There are the two the event (L, 0) and (-L, 0), while O' is at the origin (0,0).
Now transform to new co-ordinates moving at velocity v. Do you know the Lorentz transformations?
Cheers -- sylas
Ahh thanks. I can do the Lorentz.
It does seem like a much simpler method.
Appreciate it mate :)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
