Could Turbine Exhaust Temperatures Reach Below Zero Celsius?
The discussion centers on the feasibility of turbine exhaust temperatures reaching below zero Celsius, specifically referencing calculations yielding 176 K under inlet conditions of 7.8 MPa and 625 K, with an exit pressure of 1 atm (100 kPa). Participants highlight the importance of sharing calculations for clarity, noting that the working fluid is a van der Waals gas rather than an ideal gas. The conversation emphasizes the need for transparency in problem-solving to facilitate better understanding and collaboration.
  • Understanding of thermodynamics principles, particularly related to turbine operations.
  • Familiarity with the van der Waals equation of state and its application to real gases.
  • Knowledge of pressure and temperature relationships in gas dynamics.
  • Experience with steam turbine mechanics and performance metrics.
  • Research the van der Waals equation of state and its implications for gas behavior.
  • Study the thermodynamic cycles of steam turbines and their efficiency factors.
  • Explore the effects of varying inlet conditions on turbine performance metrics.
  • Investigate methods for calculating exhaust temperatures in turbine systems.
Engineers, thermodynamics students, and professionals involved in turbine design and performance analysis will benefit from this discussion.
albertov123
Could turbine exhaust temperature be negative celsius?
My calculations yield 176 K. Is that possible?
Inlet conditions are 7.8 MPa and 625 K. Exit pressure is 1 atm. (100 kPa.)
Instead of making us guess, why don't you post your calculations?
It's a bit complicated.
Is this a steam turbine?
PS: Check out the forum rules for the homework sections.
CWatters: The OP posted his calculations before this thread was moved to the HW forum, then the calculations disappeared from the thread. As far as I can recall, the working fluid was a van der Waals gas rather than an ideal gas, with certain values given for the constants in the vdW equation of state.
Albertov123,
I think you owe it to SteamKing and CWatters to paste into this thread the results of our private communications on this problem. Now you know why I don't like helping someone in private discussions. Please don't put me in that position again.
Chet
