Twin paradox initial acceleration
idea2000
Hi,
I've seen many variations of explanations of the twin paradox using special relativity, but i haven't yet seen an explanation that bothers to take into account the initial acceleration of the traveling twin away from planet Earth. Is it safe to say that this can be neglected? And, also, if the traveling twin were to accelerate away from Earth and then decelerate onto the distant planet and then stay there without coming back, would he still be younger than his twin at home?
Thanks for any help that anyone can provide!
I'm puzzled by your first question because I've never seen an explanation that doesn't take the initial acceleration into account. As for what happens if the traveling twin never returns, there is no "absolute" way for the two twins to compare their ages- the question of whether he would still be "younger" is moot.
idea2000 said:
Hi,
There are also many variations of the Twin Paradox, some of which have the same accelerations for both twins and some of which have no accelerations (involving triplets, actually). They all give the same result. It is safe to say that you can neglect the contributions of the relative aging during the accelerations.
There are also many variations on how the twins can start off together and end up apart at rest with respect to each other but it is not possible to make any conclusion about which one is younger while they remain separated. The "answer" depends on what assumptions you make, which, of course, means that there is not an answer.
The effect of acceleration is proportional to the distance between the twins. At the start and end of the trip, this distance is zero.
Explanations I have read resolve the paradox by stating that one of the twins must accelerate in order to get back. This seems to imply that the twin could not return simply by continuing in the same direction with constant velocity. Is this also true in a closed universe?
Yes, and yes.
Whenever the twins are (either perpetually, or momentarily) co-located, they will agree about their corresponding ages, regardless of their relative velocity.
Whenever the twins have (either perpetually, or momentarily) zero relative velocity, they will agree about their corresponding ages, regardless of their distance apart.
In all other circumstances, they will generally disagree about their corresponding ages.
For more information, see these two postings:
https://www.physicsforums.com/showpost.php?p=2923277&postcount=1
and
https://www.physicsforums.com/showpost.php?p=2957404&postcount=5 .
Mike Fontenot
No, in a closed universe, you can return (and be younger) without accelerating. Closed universes are not covered by special relativity, though.
Could the far away twin send a beam of light once he gets to the distant planet? Maybe the twin on Earth could adjust it for the time it took the light to travel back to Earth, or, alternatively, maybe the twin could encode his age into the beam of light and the twin on Earth could adjust for how long it took the light to travel back to Earth? Is this possible? Thanks for any help in advance...
No, No, No, and for extra measure No.
Nobody knows the time it takes for light to travel from the remote twin to the Earth twin, or from the Earth twin to the remote twin. All we know is the time it takes for light to make a round trip. Whatever that round trip time is, we can't know if it is equal for both halves or partitioned unequally between the two halves of trip. If we assume that light takes less time to get from the remote twin to the Earth twin, you will come to one conclusion about their relative ages, or the opposite conclusion for the opposite assumption. This is, in effect, what happens when you pick different frames of reference to view the situation in.
This is the reason you cannot compare absolute ages or clock times when they are remotely located and why we have to deal with relativity of simultaneity.
In SR, we arbitrarily define a frame as when the two times are equal for remote clocks that are stationary in that frame and unequal for co-moving clocks.
Yes, it is. You are asking all the right questions.
To make it easy to keep the twins straight, let the "home" twin be a "she", and the "traveling" twin be a "he".
He can transmit a TV image, holding a sign that gives his current age. When she receives that image, she can compute how much he aged during the image transit, and thus determine how old he is when she receives his image.
And likewise, she can also transmit a similar message, which he can use to determine her age when he receives her image.
Whenever their relative velocity is ZERO, they will agree about the correspondence between their ages.
Whenever their relative velocity is NON-ZERO, they will NOT agree about the correspondence between their ages (unless they are co-located). And even though they disagree, they are BOTH correct, because each of their conclusions is based on their own elementary measurements and calculations. It's weird, but it is an inevitable consequence of the fundamental tenet that the speed of any given light pulse will always be measured, in any and all inertial reference frames, to have exactly the same value in all cases. It's weird, but it's NOT inconsistent.
Mike Fontenot
Hi,
Thanks for your wonderful response, I do have one more question...
I can see how to use the invariance of the spacetime interval to calculate the dx and the dt of what each twin sees from his own perspective during the trip. The math makes sense, however, what i don't understand is how both twins can see their counterpart age slower during the trip and yet still come to the conclusion that one of them is younger than the other at the end of the trip?
For example, the traveling twin counts himself as having 100 heartbeats and counts his Earth twin as having 75 heartbeats during the trip to the distant planet. During the return trip from the distant planet, he again counts himself as having 100 heartbeats and his Earth twin as having 75 heartbeats. When he arrives at Earth, would he conclude that he had 200 total heartbeats while his Earth twin had only 150? And, if so, wouldn't he be the older one? (In other words, how can the traveling twin see the stationary twin's clock as moving slower the whole time and yet end up being than the stationary twin?) If anybody could provide any help, it would be greatly appreciated! Thanks!
idea2000 said:
Hi,
In your example of the traveling twin counting 100 heartbeats while his Earth twin has 75 is a nebulous statement. First, I'm going to assume that both twins have hearts that beat at the same rate when they are at rest together.
If you really mean that he "sees" his twin's heart beating at 75% of his own during the outbound part of the trip, then he will "see" his twin's heart beating at the reciprocal or 133% of his rate for the inbound trip (assuming he's traveling at the same speed). So the traveling twin will experience 200 heart beats during the trip and the Earth twin will experience 208. So you can see that the traveling twin is indeed younger. You can look up relativistic doppler if you want to see why the reciprocal has to be taken for the inbound trip.
But if you really mean that the time dilation is such that the traveling twin calculates that his twin's heart beat due to time dilation is 75% of his own during both legs of the trip, then we have more calculations to do.
First we note that a heart beat running slow at 75% yields a gamma of the reciprocal of 75% or 1.333 and from that we can determine that the relative speed between the twins is .661c during both legs of the trip and from that we calculatet that the relativistic doppler for the outgoing trip is 45% and for the incoming trip is 221%. If we assume that the traveling twin counted 100 of his own heart beats for each leg of the trip, he will count 45 for his twin on the outgoing part and 221 for the incoming part for a total of 266 so once again the traveling twin is younger.
idea2000 said:
... what i don't understand is how both twins can see their counterpart age slower during the trip and yet still come to the conclusion that one of them is younger than the other at the end of the trip?
The traveler (the one who accelerates at his turnaround) does NOT conclude that his twin ages more slowly than he does during his ENTIRE trip.
He DOES come to that conclusion for each of his two constant-velocity segments (the outbound and inbound legs).
But, during his turnaround, he concludes that his twin suddenly ages by a large amount. The sum of those THREE amounts of ageing by his twin (during his outbound, turnaround, and inbound segments) exactly agrees with the total amount of her ageing that he directly sees when they are reunited.
The amounts of her ageing during the two constant velocity segments are easily obtained from the time-dilation result. The amount of her ageing (according to him) during his turnaround can be easily determined using the equation I gave in this previous post:
https://www.physicsforums.com/showpos...77&postcount=1 .
The home twin doesn't accelerate, and so she concludes that the traveling twin's total ageing is the sum of only TWO terms (his ageing during the two constant-velocity segments). She can easily compute each of those two ageing amounts from the time-dilation result. She concludes that he doesn't age AT ALL during his turnaround. (And she obviously doesn't think anything happens to her own age during his turnaround, in spite of the fact that he concludes that she suddenly ages a lot during his turnaround).
The TOTAL amounts of ageing, as computed by each twin, will exactly agree (as they MUST, since the ages of the two twins are indisputable when they are reunited).
Mike Fontenot
Okay, thanks for all your wonderful responses...
I'd like to clarify for just one second just to make sure that I know what is going on...
So, let's set the information for the example first:
1. Distant planet is 4 years away (one-way) as measured by the Earth twin
2. Distant planet is only 1 years away (one-way) as measured by the traveling twin
3. Total round trip is 8 years as measured by the Earth twin and 2 as measured by
the traveling twin
And let's just say, for examples sake that each person experiences 1000 heartbeats in a year...
So, during the first leg of the trip, both frames are in free float and they both see each other aging slower. This is no problem from the Earth twins perspective as she measures her own heart rate and experiences 4000 of them, while the counting only 1000 for the traveling twin. Everything is fine and dandy. The traveling twin, however, by the time he counts up to 1000 of his own heartbeats, has only gotten to, say, 500 for the Earth twin. So where did all the other 3500 beats go? I'm guessing that all 4000 have already happened on Earth, but they haven't yet happened in the traveling twins frame (because of relativity of simultaneity) until he decelerates and turns around. Is this correct?
Okay, so if the above is correct, then during the deceleration phase, the traveling twin sees the Earth twin experience 3500 heartbeats. Then when he comes to a full stop and he starts to accelerate back towards Earth, that is when he sees the Earth twin experience yet an additional 3500 heartbeats, for a grand total of 7000 during the dec/acceleration phase.
During the last leg of the trip back to Earth, both frames are again in free float and neither is distinguishable from the other. Again, the traveling twin sees himself as experiencing 1000 heartbeats while seeing the Earth twin experience only 500. Meanwhile, the Earth twin sees herself experience 4000 heartbeats during the return trip, while seeing the traveling twin experience 1000 heartbeats.
When they finally meet to exchange information, the traveling twin has seen the Earth twin age 500 + 3500 + 3500 + 500 = 8000 heartbeats. The Earth twin sees the traveling twin age 1000 + 1000 = 2000 heartbeats. Am I getting this right?
(btw, thanks for all the help so far!)
Well, yes, there are some obvious problems.
First off, distances are measured in light-years, not years and I think you want your twins to have 100 heartbeats per year to make the rest of your example work.
Maybe you can go back and edit these mistakes before it is too late.
Now as to your explanation, you are combining things that I have offered with things that Mike has offered. I'm not going to help Mike explain his stuff because I don't agree with it. He is jumping between frames of reference during the trip which he thinks is the only way to explain the "reality" of what the traveling twin experiences. This is why there are jumps in the aging. (He also believes in negative aging in different examples.)He also applies different frames for the Earth twin and the traveling twin which is a violation of SR.
I have already explained in great detail how to explain this type of example in this thread:
https://www.physicsforums.com/showthread.php?t=447605
Look at posts #2 and #58.
Basically, the answers to your questions lie in the "fact" that the images of the Earth twin's heartbeats are still in transit when the traveling twin turns around and he then starts seeing them at a faster rate (Relativistic Doppler). The Earth twin does not "see" the traveling twin's turnaround event until long after it happens at which point he starts seeing the higher rate heartbeats. It's the "fact" that for the traveler, the times during which he sees the low rate heartbeats and the high rate heartbeats are equal but for the Earth twin, he will see the low rate heartbeats for most of the trip and it only switches to high rate near the end, resulting in a lower count of the traveling twin's total heartbeats.
Please note that this explanation describes what the twins each see and measure and has nothing to do with SR. You can also use SR with different Frames of Reference (one at a time) to learn about how SR explains the Twin Paradox.
Are the values calculated for the inbound trip for the entire inbound trip or only the u-turn part of the inbound trip?
As long as the u-turn happens fairly quickly, then nothing significant happens during the u-turn part of the trip. The values calculated for the inbound trip are for the entire inbound trip.
the traveling twin
OK, you're using a gamma factor of 4. So their relative speed is 0.968c.
And let's just say, for examples sake, that each person experiences 1000 heartbeats in a year...
No, the gamma factor (4) has to be the same in each twin's calculations ... in the above, you've used a gamma of 4 in the home twin's calculations, but a gamma of only 2 in the traveler's calculations. So you should have said that the traveler would conclude that while his heart beats 1000 times, the home twin's heart beats only 250 times.
Other than that one mistake, though, you've got the right idea. That one mistake does, however, propagate through the rest of your numbers, so you need to change a lot of your subsequent numbers to make things correct.
The correct number is now 3750 beats. If you change all of your subsequent 3500 numbers to 3750, and all of your subsequent 500 numbers to 250 (and a few other changes in some other numbers), everything will be correct. Your basic ideas and conclusions are correct.
My only other advice is to try to be much more precise in your statements.
For example, you originally said "Distant planet is 4 years away (one-way) as measured by the Earth twin". You were mixing up terminology for distance (lightyears) versus time (years). I knew what you meant, and your misused terminology didn't end up causing any problem with your conclusions. But when doing calculations in special relativity, ANY sloppiness at all in your statements CAN come back to bite you. Sloppiness that would cause no problem at all in doing Newtonian physics can cause you LOTS of problems in special relativity. Just a word to the wise.
Again, be careful in your statements. When you say "all 4000 [heartbeats] have already happened on Earth", that statement BY ITSELF doesn't have any meaning. The home twin has HER conclusion about how many times her heart has beaten, between when the traveler left home, and when he reached the distant planet, but BEFORE he changed his velocity. And the traveler has HIS conclusion about how many times her heart has beaten, between when he left home, and when he reached the distant planet, but BEFORE he changed his velocity. Their two conclusions are different. They are both correct.
Mike Fontenot
Disregard this comment. I was working from a mobile device which wouldn't let me see your original post and I got it mixed up with another example on a different thread.
Realism tells us that even if we cannot perform the comparison an underlying reality or truth must exist(an observer independent truth.). If one of the twins is moving at near the speed of light, and the other is merely on earth, he will have time passing slower relative to the other.
Now quantum physicists are fond of saying any object can appear spontaneously out of thin air, though very improbable. Suppose two twins spontaneously appear one inside his own space ship, a ship near lightspeed heading in some random direction, the other stationary on top of some mountain on earth.
Irregardless of whether they can communicate or not, the underlying reality or truth must exist even if neither of them can determine it.
For example suppose the spontaneously appearing twins appear in the following scenario:
Say 100 years pass from their 'appearance' and the twin on Earth dies, but the other twin say happened to be in a ship with a path that would pass near earth*(no acceleration or deceleration has taken place for this twin, it reaches near Earth location at the 100 year mark.)... as the ship approaches earth, they look at it and see a tombstone for the other twin... or better yet the tombstone was floating in space they see it and crash right through it. Obviously they must agree the other twin died first and aged faster.
Relativity of simultaneity can apply to non causal chains... but direct causal chains a causes b which causes c, must be in agreement for all observers, iirc. Death of earth-twin causes floating-tombstone which causes space-ship crash... if spaceship crash occurs a violation of causality would be required for disagreement.
Even if we grant you that there is an underlying realism where time is absolute (which is the assumption of LET), you still must specify the frame in which this is true in order to unambiguously define a scenario such as you have attempted to do. It appears that you think Earth fits the category of such a frame but it is constantly moving around so you need to be much more precise if you are going to be arguing on the basis of realism.
So I ask you, how do you define this frame in which time is absolute? Where is it?
Earth is merely used for familiarity's sake, but it can be disregarded.
Suppose two ships, at sufficient distance, head towards each other, in a straight line course such that they pass near each other at some point. The ships have a difference in speed, even if the travelers know not, and two twins pop into existence inside the two ships. The difference in speed causes one twin to reach 100 and die of old age, whilst the other reaches 20s. It is customary to throw tombstones into space, and they do so in such a way that it collides with the other ship.
As for the frame, it probably is some very strange frame. After all so long as causal chains are not involved everyone's supposed to be able to argue about order of events validly. But once causal chains are involved there must exist agreement on the order of events. One may imagine something like a http://en.wikipedia.org/wiki/Eternalism_%28philosophy_of_time%29" is at play.
Another intriguing question is whether the time relativistic effects would affect radioactive decay. We know chemical reactions and all known clocks would be affected. So I imagine radioactive decay would be affected in which case from an outside perspective half-life should be affected.
Some physicists theorize that protons could decay in the long term. While proton-decay is an open question, iirc. If decay is subject to time relativistic effect, then the entire ship, if we assume hypothetical proton decay, would be subjected to it. The ship whose protons decay last would be the fastest. If a man experiences a century of aging while a traveler on the ship experiences ten years, that's a 10:1 ratio, if decay is affected by a similar ratio both on board nuclear fuel as well as possibly protons(if they decay) would via half life effect last much longer than expected.
Muons have very short half lives and the effective extended life of muons at relativistic speeds has been extensively studied and confirmed in the atmosphere and in accelerators. So yes. In the atmospheric experiments, it is known that the half life muons is too short for the muons to traverse from the top of the atmosphere to sea level, but measurements show that a large proportion do make it to the ground. An observer co-moving with the muons would measure the half lives of the muons to be the same as when they are rest in the lab, but to an observer in a frame in which the muons are traveling near the speed of light the half lives are significantly longer. I think this was one of the earliest direct experimental confirmations of time dilation which has been refined in more recent accelerator experiments to much higher degrees of accuracy.
OK, if Earth is not going to define the frame in which time is absolute, and now you think there is something very strange about this frame, you need to tell us exactly how you are going to identify this frame. Saying that the future as well as the past and present are cast in concrete, doesn't help, you need tell us where is this frame. How fast is the Earth or the solar system moving through it and in which direction?
In your example, you didn't tell us the speeds of the ships with respect to this absolute frame, you just took a relativistic approach and said there was a difference in speed. And you didn't define the time at which the twins popped into existence in terms of an absolute time frame. You've got to decide if you want to promote an absolute time realism or a relativistic one. Please be specific. Tell us how you are going to identify the absolute time reference frame. No more fuzzy ideas--that won't get us anywhere.
Imagine instead of ships we have identical chunks of radioactive material moving at constant but different speeds in straight lines, no one knows exactly how fast they're moving relative to each other. Clearly if the difference in speed is great time dilation will seemingly notably affect half lifes. After a time their composition should thus measurably differ in such a way that it would be possible to order them in terms of speed differences, and to tell which rock was the slowest amongst them all.
If they were on a collision course the nature of the collision would be affected not just by differences in speed but via the differing composition. Reaching the same destination at different speeds should thus result in different stuff*(compositionally) arriving at the destination. IF the stuff was originally identical, the one receiving it will be able to note compositional change and thus be able to tell and compare the speed at which it came.
More fuzzy idea that aren't getting us anywhere. I'm sure you think your ideas are clear as a bell and they make perfect sense to you but you aren't describing precisely what you are proposing and it is so open to interpretation.
Also, you keep changing your apparatus, I suppose, because you think it buttresses your position. You can keep it simple. Just describe how you think two identical clocks would work in your proposed concept of "realism" with absolute time. You don't need to embellish your story with spontaneously generated twins, radioactive rocks, colliding tombstones or anything else. Please keep it simple and describe exacly and precisely what your idea is and what would happen from start to finish.
All you have to do is say a clock has this time on it at this location and is traveling at this speed in this direction and another clock has this other time on it at this other location traveling at this other speed in this other direction and then describe what happens and how that proves your position.
The problem is, taking any two arbitrary objects, letting some time elapse... and measuring the rate at which their clocks differ should be practically possible. If we have a collection of objects, we can take any two arbitrary objects and do so, thus looking at how they differ relatively to each other. Trying to expand this so that we can relate all objects to each other probably presents some serious problem. The problematicity of this is probably in some way similar to what occurs with gravity, in the http://en.wikipedia.org/wiki/N-body_problem" .
As you asked: putting the two things simultaneously in two objects, even if impractical is either impossible or it is possible. The question is can we relate one instant on one object with one instant or sets of instances in the other? I don't see why not, why should it be impossible to relate moments in one to one or more moments in the other? but I honestly cannot tell how this would be represented.
Are you familiar with the idea of the relativity of simultaneity?
Flashprogram, here is what I was trying to get you to do:
Suppose we have two clocks, A and B, that are separated by 1 light year. A is stationary and B is traveling at a speed of .5c toward A and they start out with the same time on them, which clock will have elapsed more time when they meet? The answer is A and can you see that I have implied a specific frame for this scenario?
On the other hand, you have proposed scenarios such as:
Suppose we have two clocks, A and B, that are separated by 1 light year. They are traveling toward each other with a relative speed of .5c and they start out with the same time on them, which clock will have elapsed less time when they meet? The answer is indeterminate because you have not stated or implied a frame in which to describe or analyze your scenario.
Do you see the difference between these two scenarios? The second one, typical of your scenarios, is not specific enough, it has no frame. It could be interpreted like the first scenario or it could be interpreted like the first one but with the clocks, A and B, interchanged. So the answer could be either A or B if we had more information.
Now you are supposing that nature has an answer to the question for your type of scenario; all we have to do is wait until the clocks meet and we will see which one has elapsed more time and that will determine which one was traveling slower and that will establish a preferred frame for nature.
And therein lies the problem: you are defining scenarios without frames and then talking as if nature is also defining scenarios but with a frame. You can't have it both ways. Either you get to define specifically what you want to consider happening in a scenario OR you have to let nature do whatever it wants and you draw whatever conclusions are valid from the measurements you can make.
So let's go back and see what's wrong with your combination of your partially defining a scenario and letting nature define the other part: When you say that two separated real clocks start out with the same time on them, you are saying something that we cannot know by making a measurement until those two clocks with a known relative speed and a known relative distance between them come together and we compare their times. After that happens, we can pick a frame, calculate backwards and determine, in that frame, what the times were on the two clocks when they were separated by a given distance. But it is totally arbitrary. We could pick a different frame and calculate backwards and show that the two clocks had totally different times on them when they were separated by a given distance.
So it is not legitimate for you to claim that two clocks start off with the same time on them without specifying a frame and then making the claim that you can determine the correct frame by waiting until they unite to compare their elapsed times and assuming that the choice of frame is determined by nature and not by you.
  • #31
JesseM, I've heard of it. The order of non-causally related events can vary between observers, even be reversed or interpreted as simultaneous, iirc.
Even if the clocks have different arbitrary times at the outset, all we have to do is establish a causal relation between the two objects, with this causal relation information can be exchanged, and on the basis of such exchanges, it can be determined that from that moment assuming all else remains constant, the clocks in the two objects differ in rate by a measurable proportion... and from such measure difference in speed can be inferred.
  • #32
You are a master at making fuzzy statements. I can't tell what you are talking about. It would help if you would define your terms. What do you mean by causal relation--is that when two observers with a relative speed between them finally arrive together at the same location just long enough to exchange information?
  • #33
If two clocks A and B travel at a constant relative velocity, which clock runs slow is a meaningless question. A second clock in the frame of A can be used to measure the time lapse of B clock and it will always appear to run slower when measured by the two clocks in the A frame, and the same is true for a second clock introduced in B frame to measure clocks in the A frame - as pointed out on a previous post, which clock runs slow depends upon in which frame the measurement is made. This is not an aging difference and therefore is not a paradox - there can be no age difference because the situation is symmetrical. Age difference only occurs when acceleration is involved somewhere during the time differential that defines the beginning and end of the experiment The pion in the lab is an example of real age difference because it has been accelerated from a rest position in the lab to near c velocity. This is a shrunk example of the one way twin paradox - you have acceleration following the initial synchronization of the pion clock in the lab frame (the pion changes from the lab frame to another frame in a jiffy or so) - but because the pion decay time is already known for at rest pions - only the lab clock and the distance before decay are needed to calculate the age of the traveling entity.
  • #34
But we've already seen the difference in clock rates will have measurable effects on things like half life, which will alter the composition of radioactive rocks or ships composed of such. Surely the physical composition of the ships cannot be frame dependent.
In previous posts related on this issue, others have commented that acceleration and deceleration need not be involved for effects to be measurable, for us to tell that clocks differ in rate of measuring time, and thus objects that are at constant speed and remain at such constant speed will experience different rates of 'aging'(passage of time) even while remaining at constant speed, if their speed differ.(example suppose we know the routes of the two ships, and put 2 messages with equal spacing along each such route. Between message one and message two of each route, the number of events in the two ships, say number of birthdays will vary between the two ships.)
Spontaneously created matter within a ship moving at high speed, close to C speed, if radioactive, will experience half life at a different rate(passing of time) as compared to the same matter created similarly in a slower ship.
  • #35
Measurements of half lives in the B frame made by clocks in the A frame will indicate a slower rate of decay in the B frame. Measurments of half lives in the A frame made by clocks in the B frame will indicate a slower rate of decay in the A frame
  • #36
Flashprogram, one problem with using radioactive rocks is that the radiation they give off is proportional to their initial size so determining their age or their aging rate from just the radiation is almost impossible so let's consider another object, totally imaginary, something like a pulsar except much smaller, that gives off a very bright flash of light at a regular interval, say once per second. And let's imagine that two exactly identical such objects exist and that one of them is traveling at 60% of the speed of light directly toward the other one which is stationary. Now let's also consider that each one can see the flashes from the other one and have been doing so for a very long time and that they are still very far apart from each other. Isn't this very much like the scenarios that you have been devising?
Now here's the question for you: How will each object observe the rate of the flashes from the other object compared to their own flash rate?
  • #37
It would seem that one would see a higher number of flashes than the other, unless I'm missing something. It would seem that if you sped the object up arbitrarily close to C, it will experience the passage of time at a very slow rate during any interval of travel.
Say the following, we can put an even simpler example:
Two ships are headed to pass a destination say X.X lightyears away, they start from the same origin, and they're both covering the same distance(as previously measured by stationary observers at the origin and destination points). One ship is traveling at .9c, the other is traveling arbitrarily close to C(e.g. .999999999999...c). As they pass the destination they leave a message of what happened during the trip(a log of activities.).
It can be seen that as the two ships were traveling very close to C, from the observers at the destination's perspective they covered the distance within a similar span of time.
The log shows that on one ship the traveler only managed to view a single episode of 'LOST', the other ship shows a year's worth of activities in the log. How can there be any argument regarding which ship had more events and thus had faster rate of the passage of time, and which had a slower rate?
  • #38
No, they would each measure the other one's flashes as occurring at exactly double the rate of their own. This is an example of Relativistic Doppler. And the faster the one ship is going, the higher the ratio they both measure of the other one's flashes compared to their own.
This is correct in your implied stationary rest frame (except maybe for your statement about them both covering the distance in a similar span of time, since one of them is very close to C while the other one is only .9c, but I don't think this adversely affects your scenario).'
By the way, you have finally specified a scenario with enough details to unambiguously interpret what is going on. Good for you.
However, in the rest frame of the "faster" ship, the destination is traveling toward him at almost the speed of light and wasn't very far away (because of length contraction) and it only took one hour to get to him, whereas the other ship is traveling away from him and is "running away" from the approaching destination so even though the "faster" ship sees the "slower" ship as having time-dilated clocks, it still takes a year of the "slower" ship's time for the destination to catch up to him.
And from the rest frame of the "slower" ship, the destination is traveling toward him at .9c and takes a year to get to him but the "faster" ship is traveling at almost the speed of light toward the destination and even though the "slower" ship sees the "faster" ship's clock as running slower than his own, it still takes one hour of the "faster" ship's clock to reach the approaching destination.
So the issue of which had more events is different from the issue of the rate of the passage of time because you are overlooking the effect of length contraction. In a given frame, a clock can be running at a normal rate but the distance covered is very short and so the number of events can be very small.
  • #39
Hmmm...
That relativistic doppler effect is very strange, almost like an escape clause. Yeah while you traveled a million light years from a distant galaxy, and your flashing machine which flashes each frame you manage to watch of a single 'lost' episode to us(you just managed to finish just a single episode during all this travel), and Earth has been using the identical flashing machine to loop the episode for a million years... there's this weird effect, and tada gotcha relativistic doppler effect meddles in and you got nothing.
The length contraction while a true phenomena I'd heard about, is still a bit tricky to picture, how about the following:
What happens if we imagine that instead of empty space, this is a very long road with identical houses at equal distances along the way(say a large neighborhood), and instead of spaceships we have very fast runners(same .9c and .9999...c). One runner breaks the mailboxes on the left and the other the mailboxes on the right. The runners reach house number 1 Trillion, and drop a message*(the message says the point at which they got while watching an identical video on their ipad.).
They each broke 1 Trillion mailboxes and passed along one trillion houses, yet at house 1T, one managed to see the whole video while the other did not. By measure of houses passed by and broken mailboxes, it would seem the length is the same even if the runners measure the road contracted to different extents.
  • #40
I think you're catching on.
  • #41
if this is so instantaneous travel could land you anywhere and would require a practically infinite energy source, good luck finding that! Since antiquity it has been searched, and no one is supposed to have found it hence, the red queen dilemma... constant progress while appearing to show zero progress.
  • #42
idea2000 said:
Hi,
acceleration and deceleration effects can not be the resolution of the so called twin paradox because we can make the interval of uniform motion long enough to neglct the effects of acceleration and deceleration.
There is no twin paradox if we look from one frame of reference...each of the twin will see that the other is younger ..when we ask ''who is younger?'' we must chose a frame .
  • #43
Mueiz said:
idea2000 said:
Hi,
This is true, we must choose a frame to decide who is younger, but if we limit ourselves to the frame in which they both started out at rest and both ended up at rest, then the twin that traveled to the distant planet will be younger and they will both eventually see and agree that he is younger although while he is traveling, they will both see the other one as younger.
While traveling, due to relativistic doppler, they will both symmetrically see the other one as aging at a younger rate. When the traveling twin stops on the distant planet, he immediately begins to see his twin age at the same rate as himself but his twin back on Earth will continue to see the traveling twin aging at the same lower rate until he eventually sees that his twin has stopped traveling and begins aging at the same rate as himself. Since they are now both stationary in the same frame, according to Special Relativity, we can compare their ages and the traveling twin will be younger in that frame.
  • #44
From Meir Achuz' post no. 4...
Huh?? Meir [or anybody], can you show equations or web sites to support this statement?
  • #45
This sounds like a distorted version of one way of talking about differential aging. In a real gravitational field, the further apart two clocks are in the gravity gradient, the larger the difference in their aging. If one uses a non-inertial frame, with metric modeling inertial force as gravity, you also see that the further apart two observers are (in the direction of acceleration), the greater the difference in clock rate. It is possible to explain almost all twin variants this way, but I don't find it the most natural way (personally).
  • #46
If you have the traveling twin at distance d change her velocity by dv, the "simultaneous" event at the origin shifts by dt = -dv*d, which is the essence of Meir Achuz' statement.
You can derive this from the Lorentz transformations by first solving for t' at the event t=0, x=d, then solving for t at the event t', x=0.
  • #47
