Two atoms and speed of sound ?
The speed of signal transmission between two atoms is primarily dictated by the speed of light in an electric field, but the reaction time of the atoms introduces a delay. This delay is influenced by factors such as momentum, mass of the nucleus, and energy of atomic bonds, complicating the assignment of a specific value for two atoms. Acceleration, including deceleration, results from applied force, with mass determining inertia and resistance to changes in motion. The speed of sound in materials is affected by various factors, including atomic mass, rigidity, and molecular bonding. Overall, understanding these dynamics requires a nuanced approach due to the complexity of atomic interactions.
elementHTTP
How fast is speed of signal between 2 atoms ?
Is it speed of light in electric field and then it slows down to speed of sound at more massive nucleus (p=mv) ?
Any change in the force is transmitted at the speed of light, however it takes time for the other atom to react and move. It's hard to assign a value to just two atoms. It's more like a simple collision than a sound wave in that case.
Is it momentum (mass of nucleus) , energy of bonds or something else that causes deceleration on fundamental level ?
tnx for answer :D
tnx for answer :D
Acceleration (which includes deceleration) is caused by the application of a force. The mass of an object determines its inertia, its resistance to changes in its motion. IE its resistance to acceleration. Higher mass objects take more force to achieve the same acceleration as lower mass objects.
The speed of sound in a material is probably a complicated scenario. Not only do we have to consider the different masses of different elements in different materials, things like how rigid an object is, how its atomic/molecular bonds work, and a dozen other things must be taken into account. It is not an easy answer.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
