Two blocks sliding on top of each other
The discussion centers on calculating the coefficient of friction required to prevent a 4 kg block from sliding on top of an 8 kg block, both subjected to a 30 N force on a frictionless table. The user initially calculated the acceleration of the bottom block and determined the necessary frictional force to maintain the top block's position. However, confusion arose regarding the nature of friction as a force that can facilitate movement rather than merely resist it. The correct approach involves understanding that friction is essential for the top block to accelerate with the bottom block.
  • Newton's laws of motion
  • Basic concepts of friction and its role in motion
  • Understanding of mass and acceleration calculations
  • Force diagrams and free-body analysis
  • Study the principles of Newton's second law of motion
  • Learn about static and kinetic friction coefficients
  • Explore free-body diagrams for multi-body systems
  • Investigate real-world applications of friction in engineering
Students in physics, educators teaching mechanics, and anyone interested in the dynamics of friction and motion in multi-body systems.
pharoh123
A 4 kg block is placed on top of a 8kg block, placed on a table with no friction,which is subject to force of 30N. What is the coefficient of friction needed between the two blocks so that the the top doesn't slide on the other one?
What i did was find the acceleration of the bottom block and then i found the force needed to push the top block at that acceleration. I considered that force the friction and found the coefficient. However, I don't think i got it right since i thought friction couldn't actually move an object and is only a resistance. So did i get right or not?
Thanks
Welcome to PF :smile:
If you show your work, we can tell you. At the very least post your answer, but showing the entire work is better.
  • · Replies 20 ·
  • · Replies 45 ·
  • · Replies 18 ·
