Two dimensional movements and circular motion
The discussion revolves around three physics problems related to two-dimensional movements and circular motion. The first problem involves calculating the rotational speed of a planet with a specified radius and varying gravitational acceleration. The second problem requires determining the angle of a cyclist riding in a circular path at a given speed and radius. The third problem focuses on finding the tension in a line from which a mass is hanging, with attempts made to resolve forces into vertical and horizontal components. Participants emphasize the importance of understanding centrifugal force and trigonometric principles to solve these problems effectively.
karljohan
Hello, i got three different assignments i need help with right now, my teacher overestimated me and my physics skills, so I'm kind of lost on these three:
(i'm european so i work with meters)
1:
A planets radius is 10 000 km. the gravitationalacceleration is g0 = 15 m/s^2 on the planets poles.
The gravitationalacceleration on the equator is ge = 0 m/s^2
How fast does the planet rotate?
2:
A cyclist is riding his bike in a circle, his speed is v = 72 km/h and the radius of the circle is r = 25 m
what's the angle alpha?
http://sv.tinypic.com/view.php?pic=xgjqef&s=8#.Vhp9zytbfo0
3:
a piece of garbage is hanging from a line. the mass of the garbage is m = 20 kg
The line forms the angle alpha = 5 degress (watch my picture) the the tension of the line?
http://sv.tinypic.com/view.php?pic=14l5ra&s=8#.Vhp_MStbfo0
1: I'm clueless.
2: clueless
3: I'm thinking of dividing the counter force into two vectors, one vertical and one horizontal. and then somehow achieve an answer.
I'm on thin ice please help godsspeed.
For 1. and 2. have you studied centrifugal force in your class?
For 3. you are on the right track, can you continue with an attempt?
Yes, i have studied centrifugal force in my class, but I'm not very good at it, and need help.
i will make an attempt at question 3:
http://sv.tinypic.com/view.php?pic=5ofitg&s=8#.Vhqp3ytbfo0
L = R
L + R = 9.82 * 20 = 196.4 N
L = R = 196.4 N / 2 = 98.2 N
sin 5 = Fy / 98.2 N => Fy = 98.2 * sin 5 = 8.55 N
cos 32 = Fx / 98.2 N => Fx = 98.2 N * cos 5 = 97.8 N
In the future, please post one problem per thread. PF doesn't put a limit on the number of threads you can create, and having one problem in each thread helps you keep the replies pertinent to that problem.
L = R
You should draw a force triangle here. The unknown force in the line is the hypotenuse of the triangle, and you have calculated the vertical force due to the weight of the garbage bag, and the included angle is 5°. Check your trigonometry.
[PLAIN]https://upload.wikimedia.org/math/5/4/d/54dbac66cd66b9ddaf8d9cbc760adf03.png97.8^2 + 8.55^2 = L = R
L = R = 98.17
can't be right
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
