Two masses attached by a spring
  • Thread starter Thread starter fuddyduddy
    Spring Two masses
The problem involves two masses, 2 kg and 8 kg, connected by a spring with a spring constant of 80 N/m, and a 4.0 N force applied to the 8 kg mass. A classmate calculated the acceleration as 0.4 m/s² by using the total mass and applied force, while the original poster attempted a more complex approach involving net forces on both masses. The correct interpretation is that the 4 N force acts only on the 8 kg mass, and the net force on the 2 kg mass is solely due to the spring force. This clarification leads to the conclusion that the net force on the 2 kg mass is determined by the spring, not the applied force. Understanding the forces acting on each mass is crucial for solving the problem accurately.
fuddyduddy
This problem was on my test today and I am not sure if my solution is correct.
A box of mass 2 kg and another of mass 8 kg are attached by a spring with a spring constant of 80 N/m. A 4.0 N force is applied to the 8 kg box. Both of the boxes move with a constant acceleration on a horizontal frictionless surface. Find the acceleration.
Fs = -kx
Fnet = ma
Here is where I'm not sure if I am right or if my classmate is right. He did this:
total mass of system = 10 kg, total applied force = 4.0 N
4 = (10 kg)(a)
a = 0.4
What I did was find the Fnet of the 8 kg box and the 2 kg box respectively and set the accelerations as equal. I think this is where I kind of went off the rails - I pictured it as the spring pulling in on both of the boxes, meaning the Fnet of the 8 kg box is 4 - Fs and the Fnet for the 2 kg is 4 + Fs.
Box A (2 kg)
Fnet = ma
a = Fnet/m
a = (4 + Fs)/2
Box B (8 kg)
a = Fnet/m
a = (4 - Fs)/8
Then set them equal: (4 + Fs)/2 = (4 - Fs)/8
Cross multiply to get: 32 + 8Fs = 8 - 2Fs
10Fs = -24
Fs = -2.4 N
When I plug in these numbers into the free body diagrams it all seems to work out, but that might be circular logic - I get an acceleration of 0.8 m/s^2
Please help! :(
Hello fuddyduddy. Welcome to PF!
fuddyduddy said:
Box A (2 kg)
Fnet = ma
a = Fnet/m
a = (4 + Fs)/2
Does the 4 N force act on the 2 kg mass or does it act only on the 8 kg mass?
It acts on the 8 kg mass, the picture was as such:
[2 kg]--(spring)--[8 kg]--> 4.0 N
And thank you for the welcome! :)
OK. When thinking about the forces acting on on the 2 kg mass, the force of gravity is an "action-at-a-distance" force (from the earth). All other forces on the 2 kg mass are "contact" forces coming from other objects in contact with the 2 kg mass.
So, if someone pulls on the 8 kg mass to create the 4.0 N force on the 8 kg mass, that pulling force is a contact force on the 8 kg mass, not a force on the 2 kg mass.
So, what should you write for the net horizontal force on the 2 kg mass?
Okay, I see now! So the net force acting on the 2 kg block is simply the spring force directed to the right. Thank you!
Yes. Good.
