Two planets of equal density, what do they share?
  • Thread starter Thread starter 1MileCrash
    Density Planets
Two uniform spherical planets of equal density but different radii present a challenge in determining shared quantities. Key points of discussion include the escape velocity, surface gravity, and orbital periods of satellites in relation to these planets. Participants emphasize that many calculations depend on both density and radius, complicating the problem. Suggestions include starting with gravitational attraction equations and calculating the mass of each planet to clarify the relationships. Ultimately, understanding the equations and their dependencies is crucial for solving the problem.
1MileCrash
Consider two uniform spherical planets of equal density but unequal radius. Which of the following quantities is the same for both planets?
I can't really attempt to solve it because it's not really a "problem."
The escape velocity from the planet's surface.
The acceleration due to gravity at the planet's surface.
The orbital period of a satellite in a circular orbit just above the planet's surface.
The orbital period of a satellite in a circular orbit at a given distance from the planet's center.
None of the above.
I can't find any equations having to do with any of things things that don't rely on either density or radius.
None of the above.
Try starting with the equation for gravitational attraction, and the equations of uniform circular motion...
Gravitational attraction is out, divide by r squared. So is uniform circular motion.
Sorry, I'm not able to parse your response.
Using the equations that I suggested solves most of the questions that you listed...
I don't understand, all of that relies on radius. I am told radius is not equal.
Exactly. Write out the equations, and see if you can answer some of the questions.
For example, write out the equations for "acceleration due to gravity at the planet's surface" for two different planets that have the same density but different radii...
Maybe you should start by figuring out the mass of each planet. Once you do that, you should be able to see how to figure the rest out.
