What Is the Black Circular Object on My Circuit Board?
  • Thread starter Thread starter overlook1977
    Board Circuit
The black circular object on the Staples Easy button toy's circuit board is identified as an integrated circuit (IC) encapsulated in black epoxy, a technique known as "Chip On Board." This method allows for direct attachment of the IC to the circuit board, with wires connecting the chip directly to the PCB. The IC contains the digital recording that triggers the toy's voice response when the button is pressed. This approach is cost-effective and commonly used in various electronic devices.
  • Understanding of integrated circuits (ICs)
  • Familiarity with circuit board components
  • Knowledge of the Chip On Board (COB) technique
  • Basic electronics principles
  • Research the Chip On Board (COB) manufacturing process
  • Explore the functionality of integrated circuits in consumer electronics
  • Learn about different types of encapsulation methods for ICs
  • Investigate the role of digital recordings in electronic toys
Electronics enthusiasts, hobbyists, and engineers interested in understanding integrated circuits and their applications in consumer products.
overlook1977
I took apart a Staples Easy button toy to see how it worked. Its very simple; attached to a circuit board there is a resistor, a capacitor, a button, and a circular black object that looks like a glob. The board is attached to a speaker and battery. So, something is telling this toy to say "That was Easy" when the circuit is closed, so I am guessing there is a microchip embedded in that odd circular black object. Is this indeed the chip, and if so does anyone know what this black thing/technique is called? Below is a link to a picture of the circuitboard. The object in question is at the top left.
http://www.flickr.com/photos/tommybear/119944332/in/set-72057594093761486/
The Blob is a chip where they keep the digital recording of the voice that you here when the button is pressed.
The technique is called "Chip On Board"
Where the IC is attached direct to a circuit board and wires from the IC connect directly to PCB. The chip is then covered with black epoxy. They do this because it is cheap.
That's just a chip or an intergrated circuit. Not much to learn how it works these days, heh.
  • · Replies 26 ·
9K
13K
